The installer is not blaming anything on anyone. It leaked and they are fixing the leak. They replaced all the broken tiles when it was originally installed. IMO the root cause of the leak is the installer did not have people with roofing experience install the panels over the clay tiles. I still think the clay tiles are a fashion statement and not the best choice for roofing. If you are content to NEVER walk on your roof, it would be fine. There are other types of tile looking roofs that would be better suited. IMO if you have the clay tiles I have, plan on removing them and installing asphalt shingle tiles under the panels. You won't see the asphalt shingles as they tuck the tiles in around the edge to keep the look consistent. My roof is over 20' high and it is not possible to clean it very well with a jet nozzle from the ground.
I have heard nothing of what the expense to me will be for these repairs. I'll keep you posted on that matter.
Most Popular Content
Remove Tiles on RooF?
The proper question is why the installer did not caution you in advance about the clay tiles, and how their quality control allowed the leaks. During the install, you can expect some breakage from handling and drilling, but the broken tiles should have been replaced at the installers expense.
Leaks come from bad workmanship, not the base materials.
PV panels can be washed from ground level with a jet nozzle.Last edited by Mike90250; 12-05-2014, 03:05 AM.Leave a comment:
I had the solar panels installed over my clay tile roof. It leaked pretty good during this last rain. Today they were up repairing the leaks and we decided to pull off the clay tiles underneath the panels and install asphalt shingles. I'm going to have them build a path of shingles to the panels so the panels can be cleaned without stepping on the clay tiles. Not sure why anyone would build a roof with such fragile clay tile covering.
Good luck.Leave a comment:
It sounds like maybe this installer is only familiar with doing flashing on asphalt singles and not on clay tiles, so that's why they talked you into switching to shingles.
I wonder how the aesthetic would be like if all of a sudden you have a path of shingles among clay tiles on your roof, let alone having to worry about how to get the water from the shingles back on to the tiles like previously discussed by other posters.Leave a comment:
What kind of mounts did they end up using, and any idea where the leaks occurred?Leave a comment:
9 Months Later....
I had the solar panels installed over my clay tile roof. It leaked pretty good during this last rain. Today they were up repairing the leaks and we decided to pull off the clay tiles underneath the panels and install asphalt shingles. I'm going to have them build a path of shingles to the panels so the panels can be cleaned without stepping on the clay tiles. Not sure why anyone would build a roof with such fragile clay tile covering.Leave a comment:
Better to just get a competent installer to begin with.Leave a comment:
I agree.
One major warning for the whole thing is that whatever the solution may and up being, some PV installers are not competent to do the roofing work and so will either contract it out to an actual roofing contractor or will have the work done by laborers who cannot recognize a reason for doing it a different way than they were taught.Leave a comment:
There are two reasonable ways they could go with that.
1. Install custom metal flashing at the bottom of the shingle roof section to carry the water back onto the tiles. If the slope of the roof is shallow, they could flash onto tiles one row down from the edge of the panels and then put the top row of tiles over the flashing.
2. Remove the tiles all the way to the bottom edge of the roof and put in proper shingles and flashing to that bottom, then set the tiles back on top of that for appearances and some protection.
Any way they do it will require attention to flashing at the sides of the array not just at the bottom.Leave a comment:
Thanks for your input. Out of 5 quotes only one wanted to do this type of install.Leave a comment:
I also got a quote and the solar co.They wants to remove my concrete flat tiles under the panels and replace them with composition asphalt shingles. They said it would make the panels look recessed in to the concrete tile. My concern is how the water get back on top of the concrete tiles. Has anyone gone with this type of installation?
You should probably steer clear of companies that want to do this. It shouldn't even be a consideration in the first place.Leave a comment:
I also got a quote and the solar co.They wants to remove my concrete flat tiles under the panels and replace them with composition asphalt shingles. They said it would make the panels look recessed in to the concrete tile. My concern is how the water get back on top of the concrete tiles. Has anyone gone with this type of installation?Leave a comment:
Based on the input here I started telling installers I'm not taking my tile roof off and they need to figure the job over the tile roof. Just got back from talking to a SunCity booth at Home Depot. SunCity would install over a cement tile roof, but they will not install over a CLAY tile roof. The clay tiles are more fragile and they refuse to take on the liability of the install. Like so many things, when you get into the details, the answer may change. Do you still agree I should find an installer that will work with my clay tiles and not replace them with a new shingle roof? All ideas are welcome.Leave a comment:
