You would be insane to build your own panels. By the time you buy all the components it will cost more than buying factory made panels
And that does not include anything for the labor to put together.
Secondly unless done very carefully and properly sealing the panels against moisture which is the enemy of solar panels will be costly and will not achieve consistent good results.
Lastly any cells you buy on ebay will not be sorted grade A cells.
They will be the rejects from some plant that makes them and without a lot of expensive test equipment you will have no way of knowing until a panel is finished and doesn't perform to design specifications.
Most Popular Content
New and Confused and in desperate need of some help
What we are looking at doing, just looking into, is building our own solar panels using the cells. This already will save a whole lot of money. We can find 1kw solar cells for around $300 off ebay.
We have also decided not to use any of the greenhouses. We are looking at getting a secondhand 1kw (1.008hp) fan. Then we will use a 1 phase to 3 phase inverter. We can get 106ah (Deep Cycle) batteries for $80 each. This might be a bit pricey BUT if this works we will see if we can get this directly from China.
Thanks for your and everyone elses help we really appreciate this. Please if you think of anything else that might help we will be to happy to hear from you.
Sincerely,
BarryLeave a comment:
Seems like an air quality study and/or installation of some sort of passive ventilation system/swamp cooler etc is going to be your best bet.Leave a comment:
Well that is not good, real poor. YOu need complete unrestricted clear view of the horizon east, west, south. Even with that is not top be confused with 12 to 14 Sun Hours. Works out to only be 4 to 5 Sun Hours.
With that said if all you get is 6 hours of direct sun only means you get maybe 2 sun hours at best. So to generate say 8 Kwh per day to run one fan only you are looking at 6000 watt solar panel, Two very expensive 60 amp MPPT charge controllers, and a 48 volt 1250 amp hour 3600 pound battery. Just the battery cost alone here in the USA is around $12,000 USD and will need replaced about every 5 years with tender loving care. Work that out for 5 years and just battery cost alone is 65-cents per Kwh USD. Does your electric company charge you more than 65-cents per Kwh when converted to USD? If not even remotely thinking of taking anything off-grid is economic suicide and bankruptcy.
Barry when we say do not take anything off-grid unless there is no other effective cost solution, we mean it. If you are paying less than about USD 90-cents per Kwh, off-grid solar is not for you. Even if you have Net Metering in SA, unless your neighbors pay for most of it is not likely going to help either as it would take 20 years or more to just break even which means you get to pay 20 years up front for electricity. Something tells me your profit margins and cash flow cannot do it.Leave a comment:
before you go buying new fans for an experiment consider getting a contactor and or timer to turn your existing fans on and off on a 10 minute on or whatever it takes to do one air change and then off for say 50 minutes If you go to 15 on and 45 off that would cut your consumption by 75%Leave a comment:
Thanks mate. Simply reading what is being said here is already getting us a bit down. BUT we are thinking of working things a bit different. We ABSOLUTELY need to find a solution or it is bust.
In SA we get full sun for 6 hours a day. So we are thinking that maybe we will take one of the houses and run it for only 8 hours a day on the 1 kw fan.
If we do this I reckon we might save a bit more (if it works). We are willing to sacrifice this one if need be to see if we can make it work.Leave a comment:
Barry. in the "off-grid" section of this forum there is an excel spreadsheet to help you calculate your needs. You're not going to like what it spits out for you though.Leave a comment:
Thank you so much for all the response. Trying very hard to keep track of them however a lot of it is going over my head.
I will go through them all again and use the internet as reference.Leave a comment:
Understood completely. All things are relative to our own experiences.
Being that Barry already referenced dropping the hp by 80% on his fans, I'm wondering if perhaps he is using his exhaust fans to obtain the same benefits he can get from HAF. The HAF fan I referenced is one of the better efficiency MegaBreeze (trade name) fans available, but that's still only maybe 20% more efficient that a low cost HAF fan. I've heard this tounge in cheek adage many times on this forum in many ways... "The cheapest way to produce electricity is not to use it." In my own experience, the power savings I'm obtaining by "going solar" is about twice what I originally calculated it would be each month when it comes to what I'm paying the POCO. I attribute that to simply to being more aware and less wastefull.
Barry, if it is HAF that you are trying to reduce the cost of perhaps this will help.
http://extension.umass.edu/floricult...houseBMPfb.pdf
Look on pages 104-106. The HAF discussion is short, but it may inspire your thinking as to how to reduce your power useage. I'm sure there are other references available on the web to help as well.Leave a comment:
That is a pretty big greenhouse. I understand now what you referring to in fan hp size when compared to the amount of cfm needed for the required air flow.As this is a greenhouse and the fans are running 24/7, I'm assuming he is talking about HAF fan arrangement (horizontal air flow) so as to prevent diseases at night and help with respiration during the day. Typically those fans use low hp. For example, a larger one (36") has a 1/2 hp motor, consumes 3 amp @ 230v (0.7 kw), and moves 14000 cfm of air.
A well designed HAF application should have a cfm fan capacity twice that of the square footage of the area being served. Simple scaleup indicates that 5.5 kw should be able to move about 110,000 cfm of air and serve 55,000 ft^2 of greenhouse. That's about 1-1/4 acres of greenhouse - pretty big where I come from.
Size is a matter of perspective. For me a 5 hp motor is pretty small.Leave a comment:
A well designed HAF application should have a cfm fan capacity twice that of the square footage of the area being served. Simple scaleup indicates that 5.5 kw should be able to move about 110,000 cfm of air and serve 55,000 ft^2 of greenhouse. That's about 1-1/4 acres of greenhouse - pretty big where I come from.Leave a comment:
Does South Africa allow grid tie solar
Even If they so it would take about 5-7 KW to offset the 1 KW fan motor
And it would have to be a net metering scheme.
Is there a way to passively vent them?
That would be the least costly alternativeLeave a comment:
First off if you want to go with solar or some other alternate power quit changing the fans. Using 3 phase limits your choices on equipment. It most likely would be better to replace them with DC units designed for solar or single phase AC. No since it adding extra cost of replacing them until you decide how you're going to power them.
WWWLeave a comment:
Those fans are really not that big in horsepower. The 5000 watt unit is about 7 to 8 hp and the 1000 watt fan is about 1.5 to 2 hp. Although even at those low hp the cost to power via solar will be very expensive.You must have a massive amount of floor area to be needing fans with that much hp. If you can drop from 5 kw to 1 kw, can you simply cycle them maybe 15 minutes on, 5 minutes off without harming your crops (or 10 and 2 or some other combination that reduces power consumption)? I think you are going to find out quickly that solar PV power is not your solution, but there are a lot of smart people on here that may be able to help you think up alternate ways to save power.Leave a comment:
