AC Submersible Pump
Wow !
I'd start with switching out the pumps to a 3 phase motor, with a electronic controller/converter That should save some $ right there.
info:
1/2 hp to 3 hp, 230 VAC single/three-phase input VFD
Are these well pumps or tank/pool pumps? Make sure they are not oversize, because that's what the
vendor had in stock when you were buying.
Then I'd look into Grid Tie solar, if the utility in your area allows it.
Thanks a lot for quick detail help. It it viable to connect AC pump with 4Kv Solar Inverter to run 1 x 3hp motor ?
i.e. Solar Panel to Inverter and Inverter to AC PUMPLeave a comment:
Wow !
info:
Then I'd look into Grid Tie solar, if the utility in your area allows it.Leave a comment:
How long does the pump run each day and how much money do you have?Leave a comment:
AC Submersible Pump
i have 2 X 3HP Falcon submersible pumps and want to run Solar On Grid. Could anyone help me how much watt solar panel, how much kwh inverter will require and other parts ?
