AC Submersible Pump
Consider using Grundfos SQ pumps to eliminate the startup load issue. Or create your own similar system with a VFD, 3 phase motor and a controller.Leave a comment:
AC pump
For single 3 Hp pump
solar panel-2.5Kw
Inverter -3KVA
Mod note - No advertising allowedLast edited by russ; 04-23-2014, 02:24 AM.Leave a comment:
This program is will work very well and you do not have to any changes in current installation and you can directly connected to existing pump. Its better you go for such system.Leave a comment:
The company has not provided the pump curves. They say they designed it as a CSR initiative and have installed them in remote areas in Africa which are not grid connected. However, the response to the product has compelled them to commercialize it. However, they say they do not have the pump curves.Leave a comment:
You also have to watch the speed of the motor. If you go too slow the natural cooling affect is negated because the fan blade connected to the motor shaft is turning too slow. Most TEFC motors don't like to go slower than 20 Hz or about 1/3 normal speed for any length of time without external cooling.Leave a comment:
Like I said, it will never work with a single phase pump motor. The link is for a VFD controller, and it can manage the available solar power, and run the 3 phase motor at reduced capacity.
Motor reduced = pumping reduced. The Pump Curves become all important.Leave a comment:
I have enclosed the solar panel requirements as specified by Schneider, again as a pdf file.
Solar PV Panel ratings.pdf
Green Regards.Leave a comment:
I have enclosed the details of Schneider Electric VFD and solar panel ratings for various motor capacities. However, they do not mention the need for batteries. Also, a few systems have been installed using these drives and panel wattages and apparently they are working fine (have not seen them personally. checked them on youtube.) Have I missed something? Or is there any difference in the actual performance V/S their claims?
[ATTACH]2750[/ATTACH] [ATTACH]2749[/ATTACH]
Thanks in advance for any clarification,
Green Regards
Wating to hear more from the experts here.......Leave a comment:
A single phase, 4KW inverter, will NEVER power a 3HP pump to full power. Using a 1:3 VFD as a soft start, you may get it to run, but the losses in a single phase 3hp motor, would require nearly 6KW to run it, and more to start it up. There are internal motor losses, Power Factor Losses and others you likely have not considered.
PV panels & inverter cannot run a motor directly, you need, as Naptown stated, batteries to stabilize the power.
Altivar 312 Solar Catalog_drive details.pdf Solar PV Panel ratings.zip
Green RegardsLeave a comment:
But if you cannot run the pump at low power or use batteries, then what little power the panels start to produce at 8am will be wasted until the sun is high enough to actually run the pump directly.Leave a comment:
PV panels & inverter cannot run a motor directly, you need, as Naptown stated, batteries to stabilize the power.Leave a comment:
