Pumping water for a slip and slide at a lake.
So solar is not an option? -
Daisy chaining pumps wont work? I haven't seen any pumps with that kind of output with low watts.Leave a comment:
No you need a pump that is capable of 25-30 feet of head and a flow rate at that height capable of what you needLeave a comment:
So I will be going to flaming gorge next week. I don't want to have to carry buckets of water up the hill for this slip and slide.
I will be picking the spot when I arrive. I will be looking for a 50 degree angle for about 40-50 feet then it turns into a jump at the lake to catch some air. I found this pump that runs on ~15 watts. I'm grabbing this mono 40w 12v panel off ebay (link). Then two of (these) pumps. They say "1/2" male NPT Inlet/Outlet - 9' 10" Max Head" I'm guessing that means it can only handle ~10' vert at .50 tubing, so I should get 20' with .25. Then hooking the second pump up at 20'.
My question is will I get 50 feet on an incline with this setup? Do I just have to hook the pumps in parallel to the solar panel and I'm off?
