This is the one I used. Didn't check to see if it was not meant for potable water.
They also have this one from Dankoff
WWW
DC pumping from deep well to cistern...
WWW, what float switch do you recommend for a DC pump? I have a Shurflo 9325 with the 902-200 controller and a 100w 24v solar panel. I was considering the SJE Pumpmaster WPS float switch because it is for potable water, but according to the installation instructions it seems to be only for AC? Here is the data sheet:
My setup uses a Shurflo 9300 series pump with a 120 watt panel and a LCB. There is a float switch in the 350 gallon cistern. I use only about 80 to 100 gallons daily in the summer. Pump is set 160' down with a static water level of 66'.
Bryan
Thanks for the help!!!
Not quite, The charge controller output is directly connected to the batteries. Lets call the 3kw inverter the load. The Load is also directly connected to the battery. The charge controller merely controls the voltage coming out, and if the battery is discharged, it soaks up the power. If the load calls for power, it also takes power, and the battery charges slower.
Well, mostly, the battery is in float, and if a load comes along and pulls power from the system, the controller simply adds more power to the keep the float voltage stable.And DC energy goes directly to the load via the inverter without entering or affecting the batteries if the system is already in FLOAT? In other words, if the batteries are charged and the system is in float, any excess DC energy from the panels gets converted to AC by the inverter without any chemical reaction in the batteries?
The controller simply does not pass the power on to the batteries, it never leaves the solar panels. and no harm is doneWhat happens to excess DC energy from the panels once the batteries are fully charged? It obviously gets wasted, but where does it go? Sorry for all the questions, but I don't know much about electricity.
I run my well solar direct for watering the orchard. You never mention how much water you need in a day. How much of the cistern will you use daily?
Originally I figured this would pump just under 2 gallons a minute. It has far exceeded that when the girls covered an old stock tank into a swimming pool. It fills the ~500 gallon tank in about 3 hours on a sunny day. Summer time there just needs to be enough sun to slightly make a shadow for it to pump. Cold winter days on a fully overcast day it will still pump at a slow rate.
WWW
Attached FilesLeave a comment:
Ok, so DC energy from the panels can be directed by the charge controller either to the batteries or a load, and the charge controller preferentially directs it to the batteries?You would want to trigger when the charge controller switches from ABSORB to FLOAT. The Midnight Solar "Classic" controller has an AUX output that can trigger on this. Other controllers may have that too. You want battery charging to be priority, you don't want the pump to suck enough power to prevent the absorb cycle from completing.
Depends, If the batteries are charging with 2400 watts, there are only 600 solar watts left to run the pump. Later in the absorb cycle, the batteries are consuming less, and then there is more power to run the pump or other large loads
What happens to excess DC energy from the panels once the batteries are fully charged? It obviously gets wasted, but where does it go? Sorry for all the questions, but I don't know much about electricity.Leave a comment:
Depends, If the batteries are charging with 2400 watts, there are only 600 solar watts left to run the pump. Later in the absorb cycle, the batteries are consuming less, and then there is more power to run the pump or other large loadsLet me ask a newbie question: If my submersible pump uses 1000w and the charge controller is receiving 3000w, is the submersible pump running 100% off direct solar electricity, without using the batteries?
That's the Signature LineAnother question: How do you get your system specs to come out under your posts? I tried to do it in settings but don't think it worked.
Thanks, Mike. The problem is that I live in the mountains in a tropical rain forest and sun isn't always reliable at the same time every day. What would be nice for me is to have some kind of "timer" that turns on when the charge controller is receiving 2000w or more.
Another question: How do you get your system specs to come out under your posts? I tried to do it in settings but don't think it worked.Leave a comment:
I use a standard intermatic clockwork timer, and it is set to run in the sunny part of the day, I have a manual override to leave it off for winter, when sun is less reliable and I don't need to pump daily
I pump to elevated tanks and have pressure all night long.Leave a comment:
Thanks for the responses. The system voltage is 48v and the inverter is Schneider 4048. I had some problems with a newly installed photovoltaic system, but it turns out that the installers just didn't program the charge controller and control panel properly. Now is producing a lot more energy. I have used the pump when the sun is shining and the system is producing 2000-3000w, with no problem, so I could maybe just keep this pump and fill the cistern manually (and save a few thousand dollars), but at the same time I like the idea of making it totally automatic. What I don't think will work for me is to use the pressurized tank, because with that the pump can turn on when the sun isn't shining.
The well guy only charges me $225 to replace the pump, so that isn't too bad. What would be even better is to have the solar dc pump hanging above the ac pump, and have the option of using either. I have a friend in Australia who does that, but I do need to have enough standing water in the 160' deep well to have both submerged, and I don't know how much standing water there is. But I can get 500 gallons/hour in the cistern with the ac pump, so the well definitely has a decent amount of water.Leave a comment:
