help needed please to set up a system
Depending on the pump some DC motors will not work correctly (or continuously) just connected to the panel.
There are DC Solar pumps that work directly from a solar panel without batteries but most have some type of controller that keeps the pump safe.Leave a comment:
I am just going to get a 12-24v dc pump , since the pond already has an ac pump...I just wanted to add a solar feature and I learnt yo can connect the 12-24v pump directly to the solar panelLeave a comment:
Huge mistake, not likely you can use any of it.I already bought the solar panel 40watt and a solar charge controller
this is the solar panel
http://www.amazon.com/ALEKO%C2%AE-40...tt+solar+panel
This is the solar charge controller
http://www.amazon.com/Docooler-Contr...rge+controllerLeave a comment:
Your first mistake was that you did not buy the pet fish first, before building the pond.
You have done this absolutely backwards.
First, you buy the most efficient pump for your size pond. Take into account the required volume and lift, and any plumbing restrictions or strainers.
Decide how many hours a day the pump needs to run.
calculate the energy required. 250W pump x 6 hours =1500watt hours.
Decision time. 200' of 16 ga extension cord = $90 or
600w of solar panels, charge controller, battery, inverter, PV panel mount, raintight shed for the gear. $5,000Leave a comment:
I want to set up a solar system. I have a 250 gallon pond
I would like to use a ac pump..
any advice of which inverter to get, along with a suitable pump and battery to make the system work...
thank you
