Will this solar panel run this pump without a battery.
Sorry, I am not good at electrics. Does this "small 12v even 6ahr" mean a battery. I am only wanting the pump to run when the sun is shining. Or should i be looking at something different. Thanks for your input. -
YES and NO. at some times the voltage will be to high .,sometimes the voltage will be to low.. and in both cases overheat and damage the motor. You need a small 12v even 6ahr to smooth out the panel voltage.. The panel is really slightly low power for that motor.. You really need a panel with about 2a outputLeave a comment:
Setting up a hot water collector using 50m of 16mm black tubing. Will this Pump run directly from this panel?
PUMP
Description:
Rated voltage: DC12V
Voltage: DC6V-DC12V
Current: 1050Ma+/-10%
Head:4m +/- 10%
Flow:550L/H +/-10%
SOLAR PANEL
Peak power: 20W
- Maximum power voltage: 17.5V
- Maximum power current: 1.14A
- Open circuit voltage: 21.6V
- Short circuit current: 1.23A
- Power allowance range: +/- 3%
- Dimensions: 49 x 35 x 2.5 cm
Thanks
