Portable Laptop Computer Charger Plan
I know this sounds crazy,,, (mabe it is) how about getting a bicycle helmut and make a very lightweight aluminium frame and stretch out a lightweight foldup solar panel on it. ?/
You only need carry a small SLA battery about 3ah to even out the panel output.. and a 12v to 19v? laptop car charger.
Even one extra laptop battery wont extend the life that much really. my net book lasts about 6 hrs on one charge and a spare and expensive battery weighs about 1 lb . that still only give a max 12 hrs.Leave a comment:
2 lbs or 1 lb or 9 lbs? Carrying a solar panel along to recharge a laptop means sitting and not hiking.Obviously your picking up rocks on your hike, the solar module weighs something like 2 lbs and the battery cant weigh more than a pound.
I would recommended the battery not the solar module. They are way over priced, what I would do is get a normal aluminum frame 30w panel like a suntech or solarworld to charge your battery before your adventures. That way your just taking your battery with you. Which should completely charge your laptop once. Also those aluminum frame panels weigh less than 9 lbs, so those would be manageable on a hike. Just a suggestion. Hope that was helpful.Leave a comment:
You could if:
1) you build a regulator to limit voltage to your laptop's voltage limit. 16V works well. 19V doesn't work as well.
2) you use a panel about 50% larger than your laptop's minimum draw. (which means around a 30 watt panel.)
3) you use it only in full sun.
If you don't hit the laptop's minimum draw it will exhibit all sorts of odd behavior - cycling on and off, refusing to start a charge etc.Leave a comment:
What about using the solar panel to supplement the built-in battery of the computer (using an airline/car power supply)? Would that have any chance of working AND making any useful difference?Leave a comment:
So you want to carry around 75 to 100 pounds of dead weight while climbing a mountain huh? Let us know how that works out for you.Originally posted by mikeUnless you will be off grid for weeks, just carry a spare laptop battery. Or get a low power tablet PC. Folding solar and battery is buy and expensive.Leave a comment:
Unless you will be off grid for weeks, just carry a spare laptop battery. Or get a low power tablet PC. Folding solar and battery is buky and expensive.Leave a comment:
Hi everybody,
I have browsed YouTube and researched a bit -- but I am a newbie to all things solar. I want to construct a simple (I hope) solar setup to run my laptop when I am in the mountains or on a hike. Here is my plan, and I would like to get your feedback:
(1) PowerFilm F16-1800 30W Foldable Solar Panel Charger (Amazon) :
Operating voltage: 15.4V, Operating Current: 1.8A
(1) Energizer XP18000 Universal AC Adapter with External Battery for Laptops, Netbooks, and More : Rated Input: 19V, 3.5A
From what I have inferred from the web, the XP18000 has built-in circuitry to regulate power input and output to/from the battery. The most appealing thing about this setup to me is that I can use the XP18000 for multiple uses in addition to powering my laptop.
With my limited knowledge, I "think" that I can simply use the (included) female 12V cigarette lighter connector from the solar panel, and a auto charge adapter from Radio Shack to plug in the XP18000 for its daily charging. I "think" that the battery will charge with this, but that it will take longer time due to the reduced wattage of the solar powered input. I also considered the 60W foldable solar panel, but I don't want to spend that much money for now. I suppose at some future paycheck, I could daisy-chain two of the 30W panels together to get effectively the same thing.
What do you think? Is this workable, or am I missing something? And thanks in advance for considering the question of a total newbie.
