Assuming I have solar power available, that will run a heat mat. Unless I reach the cutoff voltage overnight, I can use the 30Kw/hr to provide some heat as well.
I have a 3500W generator as well and will likely add either a whole house Natural Gas or Kubota Diesel generator for times I don't have shore power or sunshine.
Generator vs batteries
Freezing temperatures are a valid concern but, protection for that condition is pretty simple and embedded in my charge controllers, even the ones on lead-acid batteries! Charging a frozen lead-acid battery isn't a good idea either! Not to mention, the power available really falls.
Li batteries have a steeper drop off below 40F
unless you are running a generator, where do you get the power to run the heat mat for your Li batteries ?
Lead acid can be charged and discharged well below freezing. Li, below freezing , has a steep drop in performance, and cannot be recharged. If the BMS disconnects the Li battery from the system, as it's supposed to do, you save the battery and fry your charge controllers in the morning when the sun lights them up and they have no battery connected..
Not just lifepo4 battery, any lithium battery will degrade performance in low temperature environment. But this is no longer a difficult problem, and now some lithium batteries also have their own temperature-controlled heating function.Leave a comment:
After running a big 24VDC and currently a large 48VDC lead-acid systems, ownership costs, and routine maintenance to me are a huge hurdle to overcome. With CATL or EVE "Grade A new" ~300Ah LiFeP04 cells being <~$160 on my doorstep, I have a hard time thinking Trojan L16's or recycled Forklift batteries are a remotely good choice for myself personally.
If freezing temperatures is a concern, I would seriously suggest a heat mat for your batteries that is triggered when the temperatures fall.Leave a comment:
Li batteries vs Lead Acid, yes, there is initial cost, and there is the lifetime of the cells themselves. If your battery is for nightly use, every night, then right sized Li may be less expensive, after you have leanred to manage your system. Lead acid can take some mild abuse and still be just fine. Li is very particular about upper voltage and lower voltage, and is unable to be charged when below freezing.
Bifacial half-cells are more resilient to cloudy days and shading but, as noted extended heavy cloud cover is an issue. On our systems here in Texas, we average about ONE yearly 4-day cloud event where we don't make power continuously and have only had ONE 7-day event. Single days or half days with no or poor solar activity are more frequent.
Regarding the battery "hobby," modern charge controllers and BMS systems do the vast majority of the work assuming you aren't running lead-acid batteries. Lead-acid batteries definitely need more hands-on attention for things like adding water after an EQ to clean the plates and some Hygrometer monitoring to make sure they are healthy and the specific gravity is where you need it to be.
For me, the cost of Lead-Acid versus LiFeP04 batteries is very similar assuming similar sized systems. In my case, the 302Ah LiFeP04 batteries are significantly cheaper than lead-acid batteries of similar usable capacity.
Then there is the issue of racking for lead-acid batteries for weekly maintenance checks versus LiFeP04 which are essentially hands-free and generally are significantly lighter which makes racking easier. Both have issues with cold temperatures so, that is something to be aware of when using them in areas that aren't protected from low temperatures (modern charge controllers will protect them from cold weather).
Assuming you don't BEAT YOUR BATTERIES TO DEATH, LiFeP04 batteries are good for 7,000 to 10,000 cycles. If you take really poor care of your LiFeP04 batteries, you should still get ~5,000 cycles.
If my LiFeP04 batteries last 20 to 30 YEARS, how many generators have I replaced along the way? If you are worried about storms in a remote location, what do you do when the LPG, Diesel, Gasoline, etc. run out? I have been there PERSONALLY. Today I am a very strong solar advocate. My "FUEL" may run out when the clouds move in but, after weeks with no way to charge even a cell phone or play a radio after every ounce of gas, diesel, etc. was used up, I'll gladly take my chances with sunshine!
And yes, bad personal experience may make me a little opinionated and a touch hard-headed.
And as for past weather patterns concerning clouds... well I would not use it as a solid based considering how much our climate and weather has changed over the last couple of years.
All I can say is stay safe and make sure you have a way of keeping your batteries charged because solar panels (all types) will be working overtime to provide what people expect them to.Leave a comment:
And yes, bad personal experience may make me a little opinionated and a touch hard-headed.Last edited by sidpost; 03-09-2022, 07:33 PM.Leave a comment:
A high-quality generator like the Honda's is certainly easy to use and has a small "footprint". However, you have noise and the hassle of grabbing fuel all the time. If your fuel supply goes away (storms, conflict, shortages, etc.) you lose your power.
Solar Panels to run a small air conditioner a few hours each night will initially cost more but, decouple you from the need for fuel and those recurring costs. LiFeP04 batteries will last a really long time so, are pretty cost-effective. Storms and other things won't take your "fuel" away so you can still charge cell phones, run a fridge, etc. The negative is you need to the space for the batteries and inverter plus a location for the solar panels.
I understand the drawbacks of a generator but when I do the calculation running a generator that can use different types of fuel is cheaper then having a battery bank big enough to run my loads. Even LiFe type batteries will die and need to be replaced.Leave a comment:
Solar Panels to run a small air conditioner a few hours each night will initially cost more but, decouple you from the need for fuel and those recurring costs. LiFeP04 batteries will last a really long time so, are pretty cost-effective. Storms and other things won't take your "fuel" away so you can still charge cell phones, run a fridge, etc. The negative is you need to the space for the batteries and inverter plus a location for the solar panels.Leave a comment:
I have known of several off grid camp owners who used to use generators and switched to batteries to reduce their fuel use, cut down on noise and cut down on lugging fuel to the camp. Solar was an after thought. An idling generator is still burning fuel while a idling inverter uses very little power from a battery.
I was looking at piece of property on a large undeveloped lake, (Aziscohos Lake in Maine and NH) there was a sporting camp next door and then the nearest neighbor was about 19 miles down the shoreline and a few camps a mile or two across the lake. Unfortunately the sporting camp had an idling diesel generator for about 12 hours a day. It really impacted the illusion of a wilderness lake when the generator was running especially during the daytime when folks were out enjoying the lake. They had what looked to be hospital grade silencers but the generator could be heard a couple of miles away on the lake. The camps owners were old school but my guess was if they had gone with a battery bank and solar with diesel backup they would have attracted far more return clients. I walked away from the deal mostly due to the diesel.Leave a comment:
RE: What is more cost-effective?
1. generator or
2. deep cycle batteries charged with solar panels
Another way to think about it is that you can't really own/run/maintain #2 (deep cycle & solar) without a generator. The generator is really part of the system and to think that you can get away with off-grid solar without a generator isn't correct. The generator is required to properly maintain the batteries during periods of low sun/winter ect.
So it's either #1 or hybrid of the 2. If off-grid, I would work on the 1KW average demand at night. My off-grid home idles at about 250 watts or 300 with the TV on. That includes a modern fridge and LED lights ect... You can live pretty comfortably at those power levels. You just need to run heavy loads during times of excess power.
It really comes down to your need. But, I prefer a generator. Also, it provides reliable power compare to the solar panel on the other hand solar creates no noise.
Thanks for all the replies above.
In the country where I am now i can buy 3kg LPG for only +/- 1.50 USD .
I have read another thread here, Honda 5Kw generator = 1 gallon lpg per hour.
So, in an offgrid situation here perhaps wise to use a generator in the evenings for some heavy loads, like aircons just for a couple of hours.
In the meantime, study up on off grid PV. Any system you then acquire will be better designed and constructed for the learning.Leave a comment:
So, in an offgrid situation here perhaps wise to use a generator in the evenings for some heavy loads, like aircons just for a couple of hours.Leave a comment:
i'd make a hybrid system. medium size battery bank, small PV array, and a generator. If you run out of solar, fire up the generator to run loads and recharge. After a year you will know your usage and costs and can decide to purchase more fuel or more solar PV.
For this use, I'd get a propane conversion kit, the generator will run longer and cleaner from propane
update:
strike: the generator will run longer and cleaner from propane
insert: The engine for the generator will last longer and run cleaner on propane. (note, propane is not as dense as gasoline, so you need about 10 gallons of propane to replace 7 gallons of gasoline)Last edited by Mike90250; 05-17-2020, 04:55 PM.Leave a comment:
