azdave i already have fluids running from my pellet central heater, so a smart wifi valve and i can open and close the outside circuit easy. The problem comes in running the pipes outside, and will they be efficient enough and reliable. So yes, i also lean a bit more to the big sweeping system. But i have to keep in mind this was a very mild winter, snow was max around 50cm (20 inch), and it should get much bigger then that in a normal year. I remember that when i first got the land, i went there in February, and the snow was so big i almost could not reach the place on foot, i would say it had 150-200cm (60-70 inch). Actually we just got snow there last weekend (unusual this late in the year), and even with fairly high temperatures in the day time, and the sun reaching the panels directly now, it took 4 days for them to clear with no intervention.
You can see here my first snow cleaning tool. Took half a day to clean them
solar pete it was a request of mine to the guys installing the solar panels to make it so that if i want to add more later i could do that easily. And they say if i want they'll add some more easily. But the thing is, the back side of the cabin gets a lot of shade, even in summer. Panels are not that expensive now, i think i payed around 100euro for one. So 2-3 generator top ups worth of money. Problem is i don't think they would make that much of a difference. And if snow covers them i am back to where i started
You can see here just how low the sun gets in the winter, and how much the trees block it
Now when i am writing this post, and analyze all the pros and cons, I think if i sort the fact i don't have any more free ports on my inverter, adding some panels down on the water, on my pontoon where they should get at least a little sun all winter, at a high angle so that snow does not stay on them, cold be the best one and easiest to maintain!
That is especially since i already have 2 solar panels on it already because i have an electric motor and battery on the pontoon so that i can move around with it in the summer. In winter it sits on the shore (water level always goes down come winter time). So yeah, this could be the best one.
But even down there on the water it will not get that much sun
Here there usually is water in the Autumn, so i could park it here. You can see the sun reaches this lower part where trees are not that close.
And yes, it really is a wonderful place, i loved it since i was a kid an always wanted to have a place here. And i do feel like a little kid every time come.
