down sides to over-sized battery bank
thanks for the words of warning. while we've purchased the components of the system, we have not yet hooked anything up. because of that the batteries are not yet used so we feel adding new panels to the system now would not in any way impair the health of the ones originally purchased. would you agree with that interpretation? how many new batteries do you suggest we purchase to round out our system? thank you -
Just be careful how you wire them into the system.
Also understand that adding new batteries to existing/older ones will bring down the health of the newer ones.
It sucks but sometimes purchasing an entire new set to meet the Amp hour rating needed is the best thing to do.Leave a comment:
the 4 12V SOK's are wired in series to make 48V. at 207AHLeave a comment:
How are you wiring those 12V batteries? Are they a 48v system where you have them wired 4 in series or some other voltage and have some of them wired in parallel? And what is the Amp Hour rating of your battery system?
thanks for your advice! we are using SOK LiFEPO4 12V batteries. we have an Outback Flexmax 80 charge controller.
What do you mean when you say oversized?
Oversized for your loads or Oversized for what your panels can put out on any given day? Or both?
In your particular case and what I have done is the solar basically acts to keep the batteries topped off and run a security system when I am not there. When I am there I simply treat the place as if it were an RV without solar and run off the batteries until depleted and then run the generator which runs the whole place and charges the batteries back up then shuts down and you run on battery, repeating the cycle.
If you're running a backup generator, there are not really any downsides.
In fact, I would argue there zero downsides to a big battery bank regardless of your circumstances other than increased initial cost and increased maintenance (more battery cells) but I doubt you'll lose much water.
the idea is that our battery bank would be oversized for what our panels can put out.
that way, when we're away from the cabin for a week or 2, the batteries can receive and store an abundance of energy, for our use when we return.
thanks again for weighing inLast edited by panderson03; 01-14-2022, 09:49 PM.Leave a comment:
Hopefully he comes back with some numbers. I would love to see the capacity of batteries, panels and what he plans to run.
A battery bank that is slowly charged due to limited amps (due to pv or CC) can hurt them. Anyone that owns a battery system knows they also have to have a generator but you have to be there to charge the batteries. The OP was just looking into adding batteries without adding any charging amps. That is a Downside.Leave a comment:
In fact, I would argue there zero downsides to a big battery bank regardless of your circumstances other than increased initial cost and increased maintenance (more battery cells) but I doubt you'll lose much water.Leave a comment:
Thank you very much for your help, SunEagleLeave a comment:
Hello panderson03 and welcome to Solar Panel Talk
The downside to having more batteries then charging amps is that too little amount of charging amps can sulfate the battery plates and slowly make them die.
For a FLA type battery system it is best to have a charging current between C/12 and C/8 where C= the Battery system Amp hour value. Usually with more batteries then charging amps you can see a rate greater then C/12 which is harmful to the batteries.
So in short you can add more batteries but you also need to add more charging amps which usually means either more panels or maybe go to an MPPT type charger which is about 33% more efficient then a PWM type.
And finally having more batteries might make you wire more in parallel which is also bad because you can charge and discharge them unequally which again kills one or more of the batteries.Leave a comment:
