Help with charge controller battery settings.
If you have wired the batteries in series then you have a 200Ah system at the voltage of the 2 batteries added together which I presume is 12V each or 24V system.Leave a comment:
Hello guys,
I have wired two 200AH flooded batteries in series.
I'm using an epever mppt charge controller.
When setting up battery type should I leave it at 200AH or should I change that to 400AH as shown in the picture.
Advice will be appreciated.
Regards.Attached Files
