Just my opinion, but if your fans can just run when the sun shines, you would have a far
simpler system with no big maintenance needs, by running as many DC fans as needed in
daylight, with as may 12V panels as required to keep them going. Bruce Roe
off-grid lumber drying ventilation/solar kiln
I've done some more research on the solar kiln and I think it probably does make sense to run batteries but will stick with 12v fans to eliminate the need for an inverter.
I'd love a math/logic/sanity check if anyone is feeling generous!
Depending on the lumber type and load size, I need to be able to circulate air inside the kiln at up to 3,000 CFM and the fans generally run from about 2 hours after sunrise to 2 hours after sunset. Basically when ambient temps are higher/RH is lower in the kiln compared to outside. I've found some DC attic fans that move 1,000 CFM with 18 watts @ 12 volts so I plan to use three of them along the length of the kiln.
In my area:
June days are 15 hours long so 18W x 3 x 15 = 810 Watt Hours with 5.39 kWh/m2/day
Dec days are 9.25 hours long so 18W x 3 x 9.25 = 500 Watt Hours with 2.82 kWh/m2/day
Using a 1.5 fudge factor (MPPT charger), I need 266 panel watts in December and 225 panel watts in June. 3x 100W, 12-volt panels probably makes the most sense. Probably just get Renogy panels or something similar through Amazon.
With 5 days of backup, I need 208 ah of battery juice in Dec and 338 ah in July. The math on this makes sense because the shorter days require less watt hours but it defies intuition. A 30A charge controller will get the job done.
Probably 2x ~200ah 6-volt batteries makes the most sense for these. Any specific batteries out there that would be good for this application? The batteries can be taken off-site between kiln loads for maintenance.
Does this all make sense? I' still looking at fan options but the AC fans generally require a lot more wattage plus the addition of an inverter would add some additional inefficiencies to the system and just isn't needed as long as I can source some affordable DC fans.
I appreciate any input or red flags and I have to say the stickies in this forum rock!
EDIT:
Question: Is there a way to automatically shut the system down if the batteries get too low? Say to 50% for example? I am generally only at the site once per week or so and when I hit a period of cloudy weather, I'd rather just turn the fans off and save my batteries since weather that won't charge the batteries won't heat the kiln up much anyway.Last edited by nybhh; 11-26-2018, 06:23 PM.Leave a comment:
J.P.M. I spent a little time this AM researching passive solar and it appears to be pretty much the same exact thing as a solar kiln without the addition of some ventilation fans.
Virginia Tech has done the most work with solar kilns for lumber and their design specifies a couple of fans and all the kilns I know of use them. There are well established design guidelines for these so I am reluctant to go rougue and skip the fans.
i do own a small Woodmizer saw mill I so I do have a small but steady supply of green lumber moving through my drying space. I am willing to make an investment in a more effecient and controlled process to accelerate things and help minimize loss due to drying defects.
I was once moderately familiar with process drying equipment and methods, including moisture removal from wood/cellulose products. Sometimes equipment for wood drying presented interesting situations, particularly with respect to moisture diffusion rates into/out of wood as f(wood species, growing conditions, climate, etc.). Probably still one of the (many) engineering black arts.Leave a comment:
Original link is not working. Neither are apostrophes! Solar kiln schematic is here...
and
Solar Kiln Dry Your Own Wood Fast and Hassle-Free By Dave Munkittrick Wood is expensive. And extra-wide or figured wood is practically beyond reach. Over the 25-plus years I’ve been a professional woodworker, wood seems to have taken a cue from oil: The price keeps going up. There are ways to use less oil, but...Last edited by nybhh; 11-21-2018, 02:18 AM.Leave a comment:
The solar kiln is designed to heat up well but is insulated and enclosed so a fan is needed to remove moist air and the speed which the moisture is removed is controlled through operable vents. The schematic I linked to illustrates the cconcept pretty well.
Solar kilns are far from newfangled technology but fans are critical to their operation and grid electrical just is not feasable at this location. The kiln is very similar to an attic venting situation actually while my barn fans will hopefully speed things up a bit and help prevent mildew during still humid periods.
JPM,
Thanks for responding, real good questions. This is a small scale hobby operation so not much. The exact amount of moisture is species dependent and varies with how recent the wood was milled so it varies but volumes are generally 1500 board feet or less and that is what the kiln will be designed around. Think 1 inch thick lumber in a stack 4 ft wide by 10-12 ft long x 6 ft high with 3/4" stickers/spacers between each vertical row.
Backup ventilation is not needed since the worst case scenario is dying too fast which I can control. If power shuts down or cloudy weather, moisture will just build up and drying will stop but temps are generally lower so less moisture to deal with anyway.
Too much moisture over an extended period can lead to mildew and staining issues but that can happen outdoors in humid/still air as well.
I have not looked into passive convection but will research it, sounds interesting enough.
Thanks again.
Passive solar drying of wood is not only interesting but it's been around a very long time - much longer than PV and workable. Designs abound and are region/climate type dependent. Essentially, the wood is dried in a passively heated solar structure with the ventilation provided mainly by natural convection that's sometimes or often aided by forced convection. Some think such means are more appropriate technology. It's probably less expensive and more reliable than throwing whiz bang PV at an application.Leave a comment:
I thought wood had to dry slowly to prevent cracking and warping, or is it clamped in place in the kiln ?Leave a comment:
JPM,
Thanks again.Last edited by nybhh; 11-20-2018, 10:05 PM.Leave a comment:
How much moisture to you intend to evaporate from how much wood ?
Do you intend to have backup for the PV powered air circ.?
Ever consider a passive solar dryer w/nat. convection circ. ? Works for kilns too.Leave a comment:
Hi all. I've been running in circles around this forum for a while now and need to go ahead and get some informed feedback before I confuse myself any further!
I think I have one of the few uses where it makes sense to keep it simple and not use batteries. I basically need to add some fans to a barn where I season/dry lumber and this setup will eventually be moved to a solar kiln when I get around to building it PLANS HERE
The goal for the fans are to run "as much as possible". The more it/they run, the faster the lumber will dry and the less the chance for mold and mildew related staining but there is no minimum required for comfort. cloudy periods, etc. While having batteries and some LED lights in the barn would be nice, I think getting the timing down for the fans where I run them as much as possible without over-draining the batteries would be a serious challenge unless the system was sized much larger than I think makes sense for this.
Ideally I'd direct wire a couple of 12v fans to 1-2 100W 12volt panel, let them run when they run and be done with it. The more reading I do here however, the more I start second guessing that. Do I need 24v panels? Should I buy batteries and a MPPT charge controller? Will I need to limit the voltage coming off the panels to 12V if I direct wire? Things seem to spiral out of control and get complicated and expensive real quick.
There is a problem with the "simple" direct-wire option also in that there really doesn't seem to be many options out there for moving a descent amount of air on 12V, especially oscillating where a "typical" $40 oscillating room fan would do the job perfectly.
Can someone plant me in reality here? This thread was super helpful but I feel this person ultimately needed a bit more out of their system than I do.
Thanks for reading.
