Small off grid solar usb charging station system.
What I meant was the current, would the battery be compatible with the 12v 8A charge controller 13,9V charging voltage, but the system I'm looking at is a 100 w panel that's rated at 2,81A and the battery is AGM 32ah 12v rated at a max charging current of 7.5A, Capacity at hr10 (c10) 30ah (3.0A, 1.75V). Would that still kill the 32ah battery? Or is this fine? -
Why on earth would you use solar for this? You would be throwing away money. Do you like throwing money away?
You can do what you want easily and the really good thing is it will work better, and you can power a lot more things other than charging cell phones. It is so simple a 10-year old can make it.
Battery Charger > 12 volt Battery > 12 Volt USB Hub Charger
The beauty of it is you could oversize and buy say a 15 amp battery charger to charge a 12 volt 150 AH battery. That would be enough to charge. That would be enough to charge roughly 150 cell phones over periods of weeks/months without power. However add an Inverter and you can watch TV and have a few lights. It would cost less than your plan.
Now if you want to limit it to just cell phones and tablets, all you need is a Wall Wart 2-amp 12 volt charger, a smaller 12 volt 10 to 15 AH battery, and your 12 volt USB Hub Charger. It would still run circles around your idea and cost 1/4 of what you want to do. Enough to charge 10 to 15 cell phones over a period of a few days without power.
Thanks for the input, looking forward to your answer.Leave a comment:
Would the fact that I'd only use the system weekly, change the solar panel size? Since I don't need it to charge the battery that quickly? What amperage of a charge controller would I need? I've found a 8A charge controller, I would assume it would work for the battery, if the battery is rated at 7.5A max current?
Now if you want to limit it to just cell phones and tablets, all you need is a Wall Wart 2-amp 12 volt charger, a smaller 12 volt 10 to 15 AH battery, and your 12 volt USB Hub Charger. It would still run circles around your idea and cost 1/4 of what you want to do. Enough to charge 10 to 15 cell phones over a period of a few days without power.Leave a comment:
Would the fact that I'd only use the system weekly, change the solar panel size? Since I don't need it to charge the battery that quickly? What amperage of a charge controller would I need? I've found a 8A charge controller, I would assume it would work for the battery, if the battery is rated at 7.5A max current?Last edited by AllOuT; 04-01-2018, 06:13 AM.Leave a comment:
An inverter is required, if you have loads that need 120VAC If you can get by with 12V dc loads, or simply only using the USB output of the controller, you don't need an inverterLeave a comment:
What is your load:
30x5 = 150wh
or
30x12= 360wh
Your 12V battery needs to be 2x the size of your load.
360Wh @ 12V = 30ah. 60A is a battery found in a small car. A cheap 12V 80ah marine battery is about your only choice, or spend 2x as much for a lawn tractor battery at 60ah, depends what you can get in your area.
To charge that, you need a 100 - 150V pv panel, with a Voltage Max Power of about 18V Vmp=18V, Voc=21VLeave a comment:
What is your load:
30x5 = 150wh
or
30x12= 360wh
You need to come up with a few more numbers. Calculating power requirements in Watt Hours is a more universal way than other convoluted methods.
30000 mah = 30Ah @ __what voltage 5V, 12V ?___
30x5 = 150wh
30x12= 360wh Big difference. Most charge controllers require a 12V battery to power their internals. so that battery has to be accounted for also.
Doing this under $250 is going to be roughLeave a comment:
30x5 = 150wh
Hello, tried to make sense of what I need myself, but I cant seem understand how big of a solar panel I need, battery size, or if I can actually use solar for this purpose.
I want to make an off-grid USB charging station with a solar panel, preferably with one panel, I have 6 devices that have a total battery capacity of 30000 mah (2500 mah to spare), are there charge controllers that have at least 4 USB ports in them? I would assume if I would charge my load from the controller directly, I wouldn't need an inverter? Otherwise the charging station is a 40w load, I would assume it's more the more devices you charge. I have no clue of how long these devices would charge, I know the USB charger is rated at 5v/2.4A
The purpose of this system would be in a grid-down situation, I wouldn't use this daily, but assuming once the grid is down, I would use the system once every 5th or 6th day, I don't mind keeping the system up, but I'd prefer maintenance-free batteries. I have 4.8 sun hours where I live.
My question is, what's the most cost-effective way to make this system, does the fact that I would only use the system for USB charging change the battery capacity or panel size? Is solar even a choice if I would use this system weekly, not daily? Note: I am on a tight budget (I'm a student), I would like to spend no more than 250$ for the whole system (except the load).
Sorry if there's dumb questions, I'm pretty new to solar, and batteries and such.
I appreciate all answers, and thank you for your time.
