Houston we have a SPAMMER.
Grid tied inverters in off grid configuration.
I find that if you ask a question, you often and get labelled as confused by "experts". Important to stay safe, comply with regs and judge quality and practicalities.
I am going to wade in with an "Update as of June 2018", mindful that many engineers make their living by adding value to expensive manufactured products.
eBay and Banggood search this morning reveals:
(1) Modified sine wave inverters, 5kW peak, costs justLeave a comment:
Someone is very confused. Does not know what type of Inverter is used and does. Wished I were in sales like Amy. That is a Pigeon waiting to be plucked.Leave a comment:
Just to clear up a couple of terms being used
Grid Tie inverter. Special inverter fed by PV panels to back feed the grid. Must meet UL 1741 spec, disconnect if loss of Grid, impedance test of Grid. Pure sine
Hybrid Inverter. Even more special, often has dual AC inputs, 1=Grid, 2=Generator Meets UL 1741 also, to safely backfeed the Grid Runs of batteries. pure sine
Inverter / Charger simply uses grid to charge batteries with. Cannot backfeed or sync to grid. Often 12V for use in Camper vehicles. can be pure or mod sine wave
Plug-In GT inverter. OMG ! these never carry a valid UL 1741, seldom are efficient, and can easily start a fire. Fed by PV panels
MPPT Multi Point Power Tracking a way to electrically match PV panel to the load for most efficiency, MPPT generally should not be fed from batteries,
I am seeing a lot of I want to use ABC and then describe DFG and there is much confusion happening.Leave a comment:
We are tied to the grid, but as 'grid-assist' instead of 'net-metering'.
Second reason is that some of the grid tie type of inverters by default can run on a range of voltages(22 to 60V). This would also have positive impact to flexibility of my off grid system. 24-36-48 volts battery banks for example.
"Grid tie type" inverters cannot be used to power AC loads from a DC battery, in any case.
Well, for you, your best option is a standard off-grid inverter. They are reliable and cheap and are designed for what you want to do. I strongly suspect you do not want an AC-tied system (only reason you'd need a hybrid inverter) and are just confused as to what that entails.
Reason why I am asking this is because there are so many more available to chose from in 36V DC world than in off grid 36V DC world.
Before I pull the trigger on el cheapo unit I was looking if anyone has successful experience to share. Such a case would open up whole new world of possibilities for me.
Second reason is that some of the grid tie type of inverters by default can run on a range of voltages(22 to 60V). This would also have positive impact to flexibility of my off grid system. 24-36-48 volts battery banks for example.Leave a comment:
Thanks!
I want option # 1 from your list - but I want to use grid tie inverter instead of off grid inverter since off grid type of inverter is hard to find in 36V DC in acceptable quality. Grid tie inverters are many in 36V on DC side. Do you implying in your option # 1 that is possible to use grid tied type of inverter?
There are small inverters like the Enphase M250 that will work from 27-39 volts. These CANNOT have batteries attached to them. To use them with an off-grid system you would need a bidirectional 240 volt inverter like the Radian (to generate the AC that the Enphase inverters need to sync to) and several relays to disconnect the Enphase inverters as the batteries get close to full charge. You would also need some custom controls to provide the level of resolution you need to control charge. For the Radian you are looking at $2500 or so.
I am inquiring about possibility of using grid tie type of inverter (instead of off grid type of inverter) hooked up to 36 volts battery bank on its DC side and 110 volts fridge on its AC, side for example.
Battery bank will be charged by PV array + CC.Leave a comment:
All inputs are highly appreciated.
SIGP2101Leave a comment:
I guess I am just dense today, sorry.Leave a comment:
