2000k system only puts out 500 watt why?
This whole 34 volt thing really bugs me. Is this really normal behavior for solar panels to drop off 4 volt's with in the first year? Granted I can not get a accurate reading on my current but when Missouri Wind and Solar tested the panels all they could get on current was 5 amps at 33 volts no higher on any of the panels and they told me the panels are still working properly and within warranty limits. I mean I don't know jack about solar compared to you guys but it just doesn't seem right. I know they drop off but from my understanding it's over a 25 year span at a slow decline not rapid drops. I mean who's right the licens tech who came out spent two days going over everything and told me the panels and cc are bad or the unlicensed salesmen. My gut tells me to listen to the guy who went to school but then again he could of slept through class. 34vX5a=175w That a 75 watt drop during peak time. -
In use and working great.
Yes, exactly. The two terminals on the sides are for the NO contact. The two terminals on the bottom are for the NC contact. Some of what I've written above is probably not perfectly correct, but doesn't change the functionality as installed. I had envisioned the generation source (PV or wind) on a common contact switching between the two outputs. However, another look at the drawing linked below suggests that the contacts are separate, perhaps to keep the exposed NO contact from being energized by the PV system (and a safety risk) when the dump load is not connected and the relay is active. When wired for diversion mode, the dump load is put in parallel with the battery, which makes more sense than a SPDT switch would.
http://www.mwands.com/images/control..._12V_Setup.jpg
Here's what I did.
I ran two wires from my panels fuse, one to a top lug, and the other to a lower lug. then I ran my "Primary bank" to the upper lug, and my divert to the lower lug. Now when my system diverts it is completely disconnected from one another when they are charging. I have found that this work perfectly and I get a great charge and use from my batteries. What I would suggest though is that a better charge controller is used, these solenoids can be used on any charger (I have seen them used with normal CC of all types. never tried) I am going to test that option too.
BTW I am at 600watts in panels and I can keep (with divert to second bank) 7 nearly charged by the end of the light period. The original poster needs a little more storage for his system. My first set of batteries were FRIED! because of my ignorance and I learned that I needed more. I would suggest double checking if not triple checking the batteries health with a battery tester. You can get one at Harbor freight cheap.
Lol, sounds like I predicted that oneLeave a comment:
Speaking of inspection do you know of any UL approved MPPT charge controler in the 24 volt and 100 amp rang.
If you are dead set on MPPT, the Outback FM80 will give you 80 amps which will likely be enough for you. You'll peak shave a bit if your rated (STC) current is 100 amps, but only during perfect conditions (i.e. cloud lensing.)Leave a comment:
Ok, your understanding of ON and OFF is still not right, but the voltages are at least set in the correct order. The 27.0 volts is the ON voltage... when the relay turns ON, the solar panels are disconnected from the battery (and would be connected to the dump load, if you had one). Once the relay turns ON, since the battery is no longer getting charged, the voltage will gradually fall. Once it hits the OFF voltage of 23.9 V, the relay turns off again, reconnecting the array to the battery and allowing charging to begin again.
These voltages are definitely not ideal. By letting the voltage fall to 23.9 V before starting to charge, you are allowing the battery to regularly drop below 50% SOC. By ending the charge at 27.0 V, it is being prevented from ever fully charging, which would occur with several hours of topping off at something closer to 29 V. This combination is a recipe for early battery death. The default settings were pretty good... what motivated the change?
Some wild guesses.... The fact that you got rapid cycling between 23.9 V and 27.0 V is a bad sign, especially with an AGM battery that should probably have low internal resistance. It also might be a clue to explain how the solenoid burned up... it was probably intended to actuate the relay for short periods of time, normally, just the time it takes the battery to rest from 28.8 to 27.2 volts. By keeping the relay mostly on for the entire drop from 27.0 V to 23.9 V, during periods with no inverter load, the power consumption of the relay itself is all that will drive the battery voltage to the level at which charging can begin again (ignoring battery self consumption). That might lead to overheating of the relay, and premature failure.
A fluctuating Voc reading isn't a good thing. Voc isn't going to change with the amount of sunlight... another forum member proved that Voc could even be measured by moonlight. Voc is sensitive to cell temperature, but fluctuations like you described don't sound temp related. Bad measurement is always a possibility, but a high resistance leak could also explain it (meaning, the open circuit in Voc isn't truly open). If you really want to understand what is going on, you'll need to disconnect the panels from the combiner and measure the Voc of each individually. Measuring Isc when you have a trustworthy meter is a good idea too, although that measurement is very sensitive to sunlight and so you'll need to pay attention to the time and conditions at which the measurement is made.
It's not but should the negative side of my battery bank be grounded to earth?
I checked again to keep you all updated 33.2 to 33.6 on 6 panels and panel 7 is at 34.2 clear blue skies temp about 70F and sun almost straight up in the sky. All the panel were test by themselves disconnected from everything else reading were taken from panel mc-4 connectors .Leave a comment:
Seems like there are a fair number of incentives for that right now.
But in the long run the utility has costs. They have powerlines, transformers and transmission lines to maintain. They have powerplants to build and maintain and fuel. And providing you with a free service to 'store' your electricity for you means that, in the long run, they go bankrupt (or they have to raise everyone else's rates.)
The new model seems to be a monthly fee that is basically a "storage" fee that goes towards maintaining their infrastructure. That seems pretty fair. For us it's $5 a month, and we get a lot for that money. APS just raised theirs to $21 a month, and there's been a lot of hoopla over that.
Speaking of inspection do you know of any UL approved MPPT charge controler in the 24 volt and 100 amp rang. I been looking but haven't found any yet and I know my electrical inspector will fail me on it he gave me a hard time when I did my rough in for going by 2015 nec code when we go by 03 or 04 code here it all came down to wire length 04 was 7 inches out the box and 2015 is 9 inches I think but I would have to dig out the nec book I got. Either way he made me cut 2 stinking inches off all my wires on the spot but I passed.Leave a comment:
Well, there's only the one relay there on the diagram. Are you thinking it has one set of NC contacts (connecting PV to battery) and one set of NO contacts? (connecting dump load to battery) Or am I missing another means of control?Leave a comment:
The sky just finally cleared off at 2.51pm temp 70F to 72F panels peaked at 35.1volts with panels pointed directly at the sun but the full sun only lasted about 10 minutes before light clouds moved back in and out so the voltmeter reading is going from 35.8 to 34.3. The way it looks the sky might clear off in a few hours though. The only thing hooked to the 7 panels is the meter. I don't know if a voltmeter would cause the volts to fall from the panels. I just wish I could get a correct current reading.Leave a comment:
"ACCEPT 18V TO 34V solar panel"
A real MPPT controller accepts higher voltages than that. If your highest array voltage is 18 volts you won't get any benefit from an MPPT controller on a 12 volt system, and if the highest voltage the thing can handle is 34 volts it won't even work with most 24 volt systems. (Open circuit voltage on a 24 volt array is around 40 volts.)
I suspect this is a standard PWM controller with fancy wording.
In general, you get what you pay for.Leave a comment:
The new model seems to be a monthly fee that is basically a "storage" fee that goes towards maintaining their infrastructure. That seems pretty fair. For us it's $5 a month, and we get a lot for that money. APS just raised theirs to $21 a month, and there's been a lot of hoopla over that.Leave a comment:
opinion please
What is your Opinion of this MPPT cc? Anyone ever use this one? Past experience appreciated! I can't find any warrenty info.
Those voltage settings make no sense. Where did you come up with them? Among other things, the ON voltage needs to be higher than the OFF voltage for anything close to proper functioning. The ON voltage is the voltage at which the divert relay actuates, removing charging power from the batteries (and diverting it, if you had a dump load). the OFF voltage is the voltage to which the batteries need to fall before the relay turns off and charging power is connected to them again.
When you go to the P-3 setting, you should see live voltage first, high voltage (ON voltage) next, and the low voltage (OFF voltage) last. (Unless maybe the ONL setting got changed to ONH, which reverses the action of the relay)
Have any of you tried to wire a Watt Meter and Power Analyzer between the panels and charge controller to track panel output. I was thinking of it but was not sure. The renogy 150A looks cool but I am unsure about it due to the 12awg wiring used on it and they are usually used to track RC car battery health. I think if I feed a 4 Awg wire to those 12 Awg wires it would just burn up. http://www.directron.com/trcrmtrmt150.html#captionLeave a comment:
You blew the fuse in the meter and the readings are now nonsensical.
Might want to look into a mode called HBX. A few inverters support this mode. It uses battery power first, then transfers back to AC in when they get too low. This allows you to use mostly solar power and minimize utility use.Leave a comment:
Woah there; you don't need a dump load if you have a hybrid inverter. You program the inverter to sell back to the load when X happens. X is usually "voltage over sell limit" which works well with most battery systems.
So you are paying .08 cents a kilowatt-hour for storage. How much will the same amount of battery cost you over the lifetime of your system? A T105 can be cycled ~500 times to 50% without serious degradation, which means you can get .6kwhr 500 times for about $100. Sounds like that would cost you around .33 cents for the same service from a (cheap) battery Even if you can get to 1000 cycles you are still at .16 cents per kwhr.
Sounds like your battery is ripping you off, compared to the utility!Leave a comment:
Ya I was looking at the next grade up on that meter also but really don't want to invest that kind of money into something that I could end up killing because I am still learning. Is the warranty any good?Leave a comment:
