new NiFe battery bank avaib, orignal buyer ???
no, I don't have that info. On good news, my bank still is going strong, but it's still drinking distilled water like a camel.Leave a comment:
Not the same chemistry, but in early development of cylindrical NiCd batteries the military did an overcharge test on some 2 AH D cells. After months of 1C charging (with cooling) they tested them and found they now had 10AH cells.Leave a comment:
from what I recall,, it's slow with NiFe if you can't hith them hard, but it does not damage them. And I'm living on them, not able to flatten them to measure capacity, But last year when I increased absorb time, I saw a big increase in voltage hold overnight, and much better this winterLeave a comment:
I remember reading somewhere that back in the day in L/A cells the "forming charge" was really critical.
I am wondering if a similar situation exists with Nickel cells?
Have you ever run your bank down and measured the capacity?
Good job. I made my own battery lugs out of copper pipe, I never thought of tinning them. I guess that is a good way to stave off corrosion. Lugs are damn expensive.Leave a comment:
If it's worth doing, it's worth overdoing !Leave a comment:
Is that just a regular 3/4" copper pipe you are using? What are you tinning it with, just regular lead? Great Photos!Leave a comment:
commissioning was months light/no loads, and 40amps solar charge. Now with the extra array and generator, I can hit 95A when the sun is good.
The spec is nearly impossible to achieve with a modest setup, and the charger in my inverter has a 100A limit, won't be easy to get more than that without going to 480V @ 3 phase.Leave a comment:
I understand. Especially about loading and seasonal tweaking. Just for my own curiosity, please describe the commissioning you did. What amperage for how long.?
Thank you for the update.
I have a question.
If my memory serves me, The current manual recommends a commissioning charge at the C/8 rate for 160% of capacity.
When you applied the first charge to the cells, do you remember the charging current and number of amp hours you put in?
Thank you
