making a battery
I found a facebook page that has DIYer for these cells specifically. People that are using them for car audio and more applications. I will bother them instead. Thank you guys for your time and input! -
Get a good current meter and a scope and measure what you are really taking. Then you will have a good starting point for a system design.
Your batteries will give you 22 amp-hours. That means if you are really taking 300 amps (which you are not) they will run the amp for _maybe_ 2 minutes. (At those rates, your total capacity will be less than half the 1C capacity.)Leave a comment:
OK great that's a start. 7000 watts is 600 amps. That's doable, but it means multiple 4/0 conductors to a very large capacitor bank. At those currents, forget batteries; all of it has to come from a low impedance source. Impedance is the only thing that matters (wiring and source.)
Next you are going to have to figure out average power. Your system does not take 7000 watts continuously. Get a scope with a current probe and measure the AVERAGE current you see. If it's less than 200 amps (and it most likely is) then you need only capacitance, not battery storage.
Again, for your case, impedance is the ONLY thing that matters. It determines how much the 12V system will sag when the amplifier hits its peak draws. You are much, much better off with a 1 amp-hour ultracap with a series impedance of .01 ohms than a 1000 amp hour battery with a series impedance of 1 ohm. Do the math; the .01 ohm cap will allow the 12 volt bus (really 13.8 volts) sag to 7.8 volts; the 1 ohm impedance will allow the 12 volt bus to sag to almost zero.
Or spend $140 on a BMOD0058; that's .02 ohms, which is a great deal for that impedance. Two in parallel gets you to .01 ohms. Or spend $500 on a BMOD0500; that's .002 ohms.Leave a comment:
Those audio amps tend to be totally over rated for output power. The number is not average power,
its some peak that can only occur for an instant. If a square wave to maintain that power were fed
in, the amp would fall on its face.
To deal with the problem, real, realistic numbers need to be established. Even a starter doesn't use
7000 watts, just what voltage and current must be maintained, for what kind and frequency duty cycle?
Most audio has an average power of a tiny fraction of the possible peak. When these are understood,
solutions might be possible.
To actually get into those numbers, sounds like a job for at least 24VDC. I suppose the amp might
convert to such voltages internally, relying on the idea of a far lower average current at 12V. If so
part of the issue could be there. A good storage scope would be a beginning of instrumentation.
Bruce RoeLeave a comment:
Exactly. If you have the correct equipment, its easily possible. I could explain but I'd rather not get off topic. Especially since I'm already barking in the wrong territory.Leave a comment:
in addition to the discharge drop, not a good at that current level. Bruce RoeLeave a comment:
So let's take that 100 millisecond number. A 120 farad cap (two BMOD0058's) will droop by .5 volts if you draw 600 amps for 100 milliseconds. Again, the ESR dominates.
any significant time. But it will do better if battery stays up.
A 1000AH battery does not have a ESR of 1 ohm, 1 milli ohm would be in the ballpark. The problem
with caps is, the only way to get much of the energy out is to severely discharge them to a much
lower (possibly unacceptable here) voltage. Batteries are different in that a fairly useful voltage can
be maintained for much of their discharge. I would suggest that the correctly chosen battery, though
small, might perform better than comparable size caps.
Auto alternators, they have regulators and rotating magnets with inductance. No tests
run here, but they may be incapable of following higher frequency audio loads. Bruce RoeLeave a comment:
Most big (well designed) amps boost the bus voltage to 100 volts or so before sending it to the output stage. That's a common strategy for class-D amps, for example.Leave a comment:
Adding a very small low impedance battery is not enough.
Agm batteries are big, and heavy. Lithium batteries put out better power at a constant rate, and weighs less and takes up less space. So yes there are other options like make space for heavy agm batteries, or spend $1000+ on a lithium battery made for car audio, but I dont want to do those things.
Or strap a generator to the bumper...Leave a comment:
Just bite the bullet and install a 240V inverter and a mega watt amplifer
And just how does a 7,000w amp work on 12V ? That's over 500A DC the cables have to carry. Even going into 2 ohm speakers, it's near impossible.Leave a comment:
Well, good for you; that's the right approach at least.
So let's start with the basics. Why do you want a lithium battery for your car radio?
Is it because you can't supply the energy (i.e. power over time) that the stereo needs? If so, you need a bigger alternator first.
Is it because you can't supply the peak power (i.e. your voltage is sagging during audio peaks) that the stereo needs? If so, you will be better off with a big capacitor, or a very small, low impedance battery.
Or is it something else?
My amplifier is a 7000 watt amplifier. Adding a very small low impedance battery is not enough. Agm batteries are big, and heavy. Lithium batteries put out better power at a constant rate, and weighs less and takes up less space. So yes there are other options like make space for heavy agm batteries, or spend $1000+ on a lithium battery made for car audio, but I dont want to do those things.Leave a comment:
