If you are Grid Tie, why are you looking at batteries ? Get a back up generator and stock up on fuel. What is the longest outage you think you might have in your area?
Batteries are like a boat: a hole you keep trying to fill with money.
Still deciding between LiFePO4 and AGM
I'm 90% decided that I'm going with a bank of eight 6V Surrette AGMs, but remain intrigued with those relatively inexpensive CALB "chi-com" (as Sunking puts it) LiFePO4 cells. A 360 Ah battery could be constructed from them for around $7,300, about $3,000 more than the 415 Ah AGM battery. That's equivalent capacity if not more, with no inefficient absorption stage to take hours and hours to get the battery up to healthy resting state. On the other hand, I wonder if the LiFePO4 cells would make economic sense in a lightly cycled grid-tied application where the battery acts mostly as a short term repository of coulombs between the charge controllers and the Outback Radian inverter/charger.
Given how shallow the depth of discharge is likely to be in such case, would the AGMs be the better choice? The warranty (pro-rated of course) for the Surrette Rolls S6 series in a renewable energy application is 7 years. Would a bank of 32 LiFePO4 180Ah cells kept around 50% SOC be likely to last any longer? It seems unlikely, but I haven't seen anything that would provide much of a solid estimate.
During my reading, I came across this interesting article that discusses the LiFePO4 in an evenhanded, realistic manner. It's directed toward cruising sailboat owners, but a lot of their sort of usage applies to us as well. He begins with this warning:
It includes a comparison between top and bottom balancing, with warnings about both.Unless you want a big fat dent, where your wallet used to be, I do not believe LiFePO4 is ready for mass DIY prime time builds. Read with CAUTION!!! If you think you want LiFePO4 PLEASE READ VERY CAREFULLY! Once you are done reading this, and it makes sense to you, then please spend another 6-8 months reading everything you can including every single LiFePO4 white paper you can get your hands on.
Right now I'm thinking I'm going to just order the thousand pounds of Canadian lead and hope that Lithium makes more sense as an alternative when I have to replace it in 5-7 years. Comments welcome.
