Wow. Thanks for all the input guys. It is all invaluable!
The Klein Mutli Meter is model MM2000 from Home Depot. Seemed to have decent reviews.
The Enclosure has spent the winter still in its shipping crate and under a tarp. It's just starting to flirt with spring weather here, and NC is just humid anyway. Although we have had a whole lot more precipitation than usual lately.
I'm gonna go out today and get a charger. I want to use it for a few days and keep an eye on the changes, and so I can sleep at night. When I go back inside the cabinet I'll throw a fan at the insides too.
Due to all the things that have to be done preceding it's initial official use, it may be 2-3 months yet. In the end the battery will be in it's own cinder block insulated room (that I have to build) along with the wall of invertor/charge controllers, etc.
LiFEPo4 sitting several months NOT hooked up = freaking about self discharge = Brick?
The Voltage looks ok, ( 52.4 ) I'd bump it up a little and watch it drift back down. The charger won't make much difference unless you intended to use it daily., a 10 amp would be fine. To dry it out, I'd get a fan and move the air around, assuming you had it covered up and it trapped condensation. Using aluminum for Interconnects and Buss Bars would have never been my choice, you can already see galvanic corrosion and cankering on them. One has to assume that at least some of the contact areas have it under them and are compromised. Even the top picture shows there has been condensation on the connections, I'd be trying to figure how it got in there. Over time you'll have lots of problems.
Good Luck.Leave a comment:
I switched on the enclosure today and I'll list the exact results below. The display has 2 buttons side by side that each cycle through a top or bottom row of basic info. Without a manual, I assume they reflect the top and bottom level of batteries inside??? Or maybe they both represent the whole so you can check two different numbers at once. Cause both rows said the exact same thing as I cycled through both buttons.
" 0 A "
" 0 W "
" 52.4 V "
" 66F Tmp "
" 1.0 Ah "
" 52 Wh "
" E F "
" 0% Fuel "
" 0% SoC "
" 0 A "
"0 A" is the current going into or out of the battery, zero in this case as the battery is disconnected
"0 W" is the power going into or out of the battery. It is equal to the current x battery voltage
"52.4 V" is the overall battery voltage
"66F Tmp" is the temperature. It would be interesting to know where the temperature is being measured. The sensor should be in the middle of the battery pack so it is measuring the battery temperature not just the temperature in the cabinet.
"1.0 Ah" I would think is something to do with the amount of energy drawn from the battery. I would think that this is reset to zero when the battery is fully charged.
"52 Wh" Is the same as the Ah drawn but expressed as power (battery voltage x Ah)
"E F","0% Fuel" and "0% SoC" are all different ways of showing the amount of energy left in the battery. I would think these figures have no meaning until the battery is fully charged at which the SoC and % Fuel should be set to 100%.
A) condensation on all the cross bars bridging cells. (stupid question, but how do I wipe them off without shorting anything out or electrocuting myself???)
B) the black squares on every 3 cells (8 on each level = 16 total) (the BMS Sensors???) were all blinking, even though I had the battery bank turned off.
C) the top row and the bottom row had 24 cells each. So the whole bank has a total of 48 cells. (Is that 1 cell for each of the 48V that the system is?)
I went by Home Depot and got a $99 Klein Multi Meter. - Depending on your advice I'll try to check the cells tomorrow. From the looks of the inside of the enclosure I'm not sure how many of the bottom row I can actually reach.
I'm still trying to figure out where I can actually go buy a 48v charger in person instead of having to order one online and wait. Even if I have to drive an hour away to get one. But if this thing is "dead" would there be any special instructions or specific charger to trying to revive it before officially pronouncing it a lost cause?
SimonLast edited by karrak; 02-29-2016, 11:39 AM.Leave a comment:
I don't think you have to worry about the state of charge of the battery, the overall battery voltage of 52.4 volts equals 3.275 volts/cell (52.4/16) which is around 50% full. Worth confirming with your multimeter. You can make the measurement by placing one of the multimeter probes on the end of the cable coming from the battery to the fuse and the other going to the current sensor.
It is more than likely that the fuel gauge will not start reading correctly until the battery has had its first full charge.
I see several issues with the design and construction of the electronics but they can be looked at later.
SimonLast edited by karrak; 02-29-2016, 11:37 AM.Leave a comment:
No, it's not 1 volt per cell. It looks like you have 48 180AH CALB's 16 in series times 3 in parallel. A 540 AH bank. I also looks like the bank is at 52.4 volts. Measure it with the meter and see.Leave a comment:
OK. Aside from getting a 48v charger, what Amp, or Amp rating should I be looking for?Leave a comment:
get to a golf course that has cart sales. even a cheap 48V battery maintainer will be better than nothing. And at only 48V, it looks like you are close to having nothing, Even the BMS (which is always on and bleeding power away on this pack) says 0% charge. With the cells low, you dont want to charge them very fast at all, and if below freezing temp where the battery is, you CANNOT charge the cells till they are above freezing (all the way through the pack)
This gallery has 10 photos.Leave a comment:
Hey guys,
" 0 A "
" 0 W "
" 52.4 V "
" 66F Tmp "
" 1.0 Ah "
" 52 Wh "
" E F "
" 0% Fuel "
" 0% SoC "
" 0 A "
I'll also attempt to upload the pictures I took. A couple of things I noticed immediately was:
ThanksYou do not have permission to view this gallery.
The problem here is no one knows if the BMS system is active and what it's Parasitic Load drain on the battery is. The Cell boards, Controller and Disconnect solenoid could all be drawing power on top of the self discharge.
Besides knowing the Voltage it would also be nice to know the temperature of the batteries since they are sitting outside.Leave a comment:
LFP batteries are shipped at 50 to 60% SOC. They have a 1% discharge per month, so like Sunking said, they can go for a year without charging. 27KkWh is about 560AH at 48V so they are discharging about about 6AH per month. That's like nothing.
You really need to get a voltmeter reading so you know where your at. If you want to charge them, and they probably don't need much, I would get a 48V 3 amp LiFePO4 charger like this one ( http://www.batteryspace.com/Smart-Ch...CE-listed.aspx ) and give them 4 to 6 hours charging.
I wouldn't charge them any higher than 60% SOC until they are put into service. I believe you want the voltage between 52 and 53 volts while they are waiting to be installed.Leave a comment:
Mike90250, I'm truly sorry about that. That didn't even cross my mind. Since the link was from the actual manufacturer I got it from I was just trying to show what it was I had.
I'm on the road without a computer and just my phone so I didn't know how to just show a picture.
Seeing as how I was kinda shedding negative light on that very same company it never occurred to me. Honestly. I'm not malicious. Just probably naive and maybe not too bright.
Thanks for your patience with me.Leave a comment:
When you start posting sales links for people to spend $ at, that's spam, and we'll flush you right out. Links to mfg's pages are OK. Just not sales links..Leave a comment:
Thanks for the input.
As i recall, the display is just an alphanumeric one that only says the % of total charge I think. When I get back from work Sunday I will take some pictures and meter readings.
I was looking on amazon at some battery chargers. Most seem to be for lead acid specifically, but as I understand it I should be fine if I watch the charge and unplug it before its full.
Full disclosure: out of my insane paranoid desperation I have posted onto two other forums looking for advice, thinking that different forum's members would have different perspectives or advice. And honestly collectively it absolutely has proven somewhat true. However this apparently has offended some members who evidently frequent all of them. I never realized this was such a taboo action to take. So I apologize. And if this comes across as spam (although i honestly cannot see what such a motive would be) then I'm sorry for sounding so pathetic, but if anyone cares enough I could validate every disgusting woeful detail.
Thank you to those who have offered legitimate advice. If someone doesn't ban me for some reason then in a couple days Ill post some pictures and readings.Last edited by danewguy; 02-26-2016, 09:54 PM.Leave a comment:
FWIW thi sguy was banned on DIY EV forum for asking this question. It appears he is a SPAMMER.
