If for any reason you over discharge down to 10.5 volts game over, you have a $1000 boat anchor and not chit you can do about it. No Charge controller will save you. That takes a LVC circuit to protect you.
				Smart money using Chi-Com cells is Bottom Balance. Here is why and escapes Karrak. Chi-Com cells capacity tolerance is SLOPPY of -3/ +15%. That means if you buy 100 AH cells the lowest can be 97 AH and highest is 115 AH. Real SLOPPY tolerance and gives you a big problem to have to work around.
				You now have to buy a single cell LFP charger like a Cell Log 8. It will require a rather large expensive DC 18 volt 50 amp power supply. You got one of those yet. The Cell Log 8 will cost you $250 plus a power supply.
				A weak later you notice your inverter will not stay on. For whatever reason you let you battery voltage drop to 11.5 volts. Everything should work with 11.5 volts. What is wrong? You measure cell voltages and you notice 1 of them, the weak 97 AH cell is 2.2 volts and the rest are around 3.1 volts. What happened?
You failed to monitor cell voltages with an expensive BMS that monitors each cell voltage with a Low Voltage Cut Off relay to disconnect the battery when the weak cell reached 2.9 volts. Th eweal cell reached 0 AH capacity and the three stronger cells eat it with reverse current. Your brave weak cell sacrificed it cell so the three stronger cells could survive. So he self destructed and you now have a $150 worthless battery to replace. If only you had spent another $500 in BMS that could have prevented that o ruse your expensive Cell Log 8 to somehow get your attention and shut down. That is the risk with Top Balance. The way you prevent it with Top Balance is a very expensive BMS with built in LVC and cell monitors with logic control.
				But there is another way to do this. You have to know your stuff. Bottom Balance. You get your new cells. Again weakest is 97 AH and Strongest is 115 AH. We connect them all in parallel just like Top Balance. Except this time we discharge them, not charge them. We can use a large high wattage resistor or if you bought the Cell Log 8 we use it. We discharge them to 2.5 volts at rest. When at 2.5 volts we now have equal capacity and equal voltage Every battery has 0 AH and 2.5 Volts.
				Lastly next time you whine about SK, you had better think my friend. No one on this forum or anywhere else will go to as much trouble, detail, and time to help you as i will. No one but SK will do that for you.
	Simon
