The cost is 3 times as much as FLA, so unless you have a weight issue or storing them inside they do not seem to be worth it.
No sulfation, so no need to keep or desire them to be fully charged.
PSOC operations are not only totally possible, but from a lifecycle standpoint, encouraged!
Ability to walk away from them in a discharged state and return a year or more later at nearly the same SOC. (no parasitic draws of course)
So IF that operational freedom is important and represents a big break from maintaining a lead-acid based project badly, this could be a major turning point for many.
A bench-top project or Golf-Cart provides the hands-on that is so important, but the biggest thing about it is that unlike mere talk, experience even at the small level, breaks the so-called "lead-acid" operational mentality and prepares you for the bigger stuff should one want to go there.
Put it this way - I'd first trust the guy with a bench top flooded, rather than a guy whose only experience is with AA flashlights merely *talking* about wet-cells.
Anyway, all of this is old news and has been hashed to death since 2008 or so in most forums. I think many are just burned out of repeating the same thing over and over, or more likely, going lifepo4 has turned the corner into being a commodity product. If you want it, it is easy to get these days.
