lithium maganese cells
If they are GBS, they are not less expensive than Calb. I do not know of a less expensive LFP than Calb. Having said that I do have GBS batteries in my cart and like them. I knew something had to be amiss because Lithium Manganese are more expensive than LFP. Only cheap Manganese batteries out there are the Nissan Leaf model years 2011 and 2012 that had a recall. It is Nissan's stock they got caught with, and sold to recover some losses EV shops bought them off Nissan for pennies on the dollar, disassembled the battery packs, removed the modules, and sell them to the unknowing public as new. Not really a bad deal, but at least folks should know what they are getting. -
Ah, ok that would be either GBS or something similar. GBS cells are lifepo4, BUT just a *dash* of manganese thrown in, making them LiFe(Mn)Po4. Still basically 3.2v nominal lfp cells. This added ingredient obtains results that they like, much like Winston, which are also LFP, but use yttrium, making them LiFe(Y)Po4.
At the end of the day, we are still dealing with 3.2v lifepo4 for the most part. One other biggie is CALB, which uses no additional ingredients, but refines the phosphate for ever increasing current rates.
Still, this is wholely unlike the 3.7v nominal cells which are not LFP, which may contain large amounts of manganese, like LiNMc which are usually small cylindrical types used in powertools etc. Avoid those for your application.
I like and use GBS cells in my own solar application.
There is no real trick to maintaining LFP. The rules are pretty easy:
1) Don't charge any cell higher then 3.6v
2) Don't discharge any cell lower than 3.1v.
3) You don't NEED to always fully charge them, (of course you need to have calculated your capacity right in the first place to do this.)Leave a comment:
Not a very good guess, never seen that ad and the cells I was offered, are brand new straight of the line from the Chinese manufacturer and 50-100ah cells.Take $100 of the ad price, the fact they come in 100ah and 3 year warranty, so nothing like the ad rip off.Leave a comment:
Let me guess, they are advertised as new Nissan Leaf Modules from 2012 right? Along the lines of this ad right?The lithium manganese Ive seen, been offered and interested in, are only 3.2-3.4v, half the price of lifepo4 and guaranteed for 2500 cycles. They are used in Ev's and also in off grid systems and when you look at the growing number of lithium variants, they seem to be close to the top of the range along side lifepo4. Price is big thing for most people, so it's very relevant to investigate all options before deciding a direction.Leave a comment:
Thanks and interesting. The lithium manganese Ive seen, been offered and interested in, are only 3.2-3.4v, half the price of lifepo4 and guaranteed for 2500 cycles. They are used in Ev's and also in off grid systems and when you look at the growing number of lithium variants, they seem to be close to the top of the range along side lifepo4. Price is big thing for most people, so it's very relevant to investigate all options before deciding a direction.
I'm one of those people who likes to understand the entire technology and don't just listen to spin or those with bias to certain energy directions. To me everything is worth looking at and researching, so I get the best outcome soft the future.
It's a pity there is not enough readable information on the different lithium technologies, if there was we would be able to make better informed decisions, rather then have to stumble along trying to disseminate all the garbage put up by those with vested interests.Leave a comment:
Any chemistry other than LFP is the wrong application for solar.
On a scale, the lineup is like this from most stable, least density (large) to least stable, most density (small).
LiCo02 - least stable. smallest / highest power density. 3.7v nominal
LiNmC - middle of the road. 3.7v nom
LiFePo4 (LFP). Most stable. Largest / least power density 3.2v nominal.
There are varying chemistries in between, and special-sauce additives that are all competing for investor's money. LFP is yesterday's news - but that doesn't mean it is bad! LFP is greedy - that is it doesn't actually like giving up oxygen atoms, but all the rest do so willingly.
As you go up the scale, you are paying for super high-discharge rates and tiny sizes, something like C10 or more if necessary. Nobody is going to need that capability with solar. In fact, even the LFP's could be considered somewhat too-good, that is nobody who designs a bank properly is going to exceed 0.5C.
Also note that ONLY LiFePo4 is a nominal 3.2v cell, whereas all the rest are 3.7v nominal, and thus require different charging voltages and EXTREME charge voltage monitoring. Take one of the non-lfp cells beyond 4.2v, like to 4.3v and you have a really bad situation. Take an lfp slightly above 3.6v and you incur cell damage, but not catastrophe - that takes about 30v overcharge. See the difference in safety right there? Note that I'm not advocating being careless with lifepo4 either.
Fit the battery to the need. There is no need for any power-density higher than LFP in a solar setup. Topping that off is that they are the SAFEST of all the lithium chemistries out there since they are at the bottom of the list. They are basically what agm's want to be when they grow up.
The best advice I can give is to STOP learning from investor sites or news media outlets about lithium. They are paid to SPIN the facts, if they actually know them. Listen to the professors and others in academia who actually built them and used them instead. Prof Jay Whitacre comes to mind.
This video from Prof Jeffrey Dahn is invaluable. It goes beyond just EV cars and gets to the chemistry questions.
Now we're talking.Leave a comment:
I agree they are safer than LiCo, but still need Thermal Management. For solar LFP is the ticket as they require no thermal management, half the cost, and last much longer. Just makes it a no-brainier. LFP is on the low side of energy density of roughly 100 wh/Kg compared to 120 to 150 for magneses and 200 plus for LiCo, but it is that higher density that makes them unstable. High density is not a requirement for solar, long life, cost, and safety are the most important factor for solar and no better solution than LFP. Heck even DIY EV types like myself use LFP in my golf cart.Leave a comment:
That's interesting, haven't read anything like that. This is what I've read about them at a number of sites, but yet to find some real information on them and have met someone who has been using them for a number of years and says they are ok.
Your trusted source for investing success | Since 2008, focused news, education and expert picks in Resources, Tech, Life Science & Cannabis.
"Lithium-manganese batteries may only have about two-thirds the capacity of their lithium-cobalt counterparts, but this type of battery is considered much safer in terms of thermal stability. Lithium-manganese batteries are used in hybrid and electric cars such as the Chevy Volt, as well as in e-bikes, power tools, portable electronics and in medical applications. Lithium-manganese batteries boast about 50 percent more energy capacity than lithium-nickel-manganese-cobalt batteries. This particular chemistry can also be designed for either optimal longevity, high specific power or high capacity."
I know a bit about then, enough to know this raises all kind of Red Flags.
First there is no less expensive lithium battery than LFP. There is no safer lithium than LFP. So when someone offers you a lithium chemistry that is twice the cost of LFP less than LFP means there is something very wrong. If I had to guess it is all the batteries Nissain got stuck with they used in the LEAF, when they had to change th edesign because they were dying in two years and now people bought them up for pennies on the dollar trying to find suckers to buy them.
Secondly Lithium Magnese is a OK battery with high energy density, but that high energy density makes them unstable and like Lithium cobalt are dangerous and have a bad habit of catch fire if careful thermal management is not used in a BMS. All EV's use extensive Thermal Management, no solar system has any kind of BMS made for lithium.
Lastly like Leaf owners learned the hard way, Lithium Magnese only last a couple of years. There is no longer lasting, safer, or inexpensive lithium out there than LFP.Leave a comment:
Does any one have any information regarding lithiun maganese battery cells. I'm using lifepo4, was about to order some more when the supplier offered me great prices on lithium maganese cells, half the price of lifepo4. Had a bit of a look around about them and they seem to be much better the lifepo4, other than they don't have the same energy density.
Any info would be appreciated before making a descision. Thanks.
