I took the earlier advice, capitulated and bought a Watts Up unit. Brilliant. This was exactly what I needed all along. Early results of testing are in a related thread below:20121025_172443.jpg
How much current can a 12V 5Ah SLA battery supply?
No sweat then! For some reason I thought you were using the agm to charge the cellphone battery. Cool project!Leave a comment:
Bear in mind I don't need to replenish the full 1.25Ah daily. I have tested the phone unplugged and the battery lasts several days. But thx for the feedback.Leave a comment:
Personally I'd up that to about 15 to 20 watts - even though 5ah battery replacement costs are cheap, it would cut down on the hassle of driving to the remote site with a bit more power if insolation is limited. BUT now that I think about it, if you are fully charging / discharging the cellphone battery daily, you are only going to get 300 or so cycles out of the cellphone battery anyway. Ok, so even if the panel is on the smallish side, you just take both a cellphone battery and a new 5ah agm to the site yearly.Leave a comment:
The results are in. 4 hours after I charged the battery, the voltage read 13.14. I fully discharged the phone, which then caused problems with the phone when I put it on the charger, plus the charge controller was flashing red saying the battery was bad. I think this new charge controller is sick. Anyway, after lots of stuffing around, I managed to 100% charge the phone from the battery. After leaving it overnight disconnected, this morning the battery reads 12.54V. According to the guide above, this means a full charge of the phone used 25% of the battery. Sounds like not too much drain.
A new charge controller is on the way, courtesy of the sales guy, and I have ordered a 10W panel. Looking forward to mounting the thing outside for a few weeks.Leave a comment:
Yeah that Watts Up unit is what I need. $60. Hmmm. I already have a multimeter. Pity there isn't a cheaper single function version.
I have started on the tests you suggested. I actually have a 10W panel on order, so I will redo the tests with the panel in full sun to see how it compares with the charger at 500mA.
Do you use this thing daily? Are you willing to go more than one day to recharge the agm?
My third prototype will involve a custom pan tilt zoom phone using servos and an Arduino board that I will be able to remotely position for photos / video to monitor the property. It will be on top of the highest hill. I have already put a telegraph pole into the ground. Waiting on the hardware.Leave a comment:
If you really want to get into it, a small inline dc ammeter like a "Watts up" unit could be handy. Powerwerx and various RC places have them. It keeps a running total of power along with other useful data.
For the time being, you could just drain the phone in a worst case condition. Starting from a fully-charged agm, recharge the phone. Measure the agm voltage after a 4 hour rest as a worst-case discharge point. Using the programmable supply, emulate a 10w panel by charging the agm at 500ma. If the worst case scenario in Australia is say 3 hours solar-insolation, just let it charge for 3 hours and pull the charger off. After a 4 hour rest, measure the agm terminal voltage to get an idea of how well your panel would charge the agm in only one day referring to the typical SOC voltage you used earlier.
That's the other question - do you use this thing daily? Are you willing to go more than one day to recharge the agm? In either case, it sounds like you are in the ballpark already, but you've got the tools to fine-tune it if you want to. Looks like a nicely built project - I wish mine looked as good.Leave a comment:
Yes, I have decided to go with a 10W panel as it has been working fine on the existing prototype, not having missed a beat in 3 months. The 5W panel just didn't cut it.
One thing that has been really difficult with this project is to work out how much power the phone consumes. I know that when it is dead flat and I hook it up to a charger, it draws 280mA for 4 hours, then slowly goes down to 10mA over the next 2 hours. That is easy to watch with a multimeter. The tricky bit is once it is fully charged, how much it draws over a 24 hour period. Mobile phones were not designed specifically to be plugged into chargers 24x7, although I have found they can handle it - mine has been plugged in for 3 months. Sometimes when charged, they will draw no current at all. Other times later when you look at the multimeter they are drawing 100mA. This you would expect because eventually the Li-Ion battery depletes. But it has been hard to determine, which was key to my calculations of what panel size I needed. I thought 5W would be fine to keep the SLA battery topped up. It turns out that it was not enough for the charge controller.Leave a comment:
It might be most cost effective to just continue with the small 10W panel and replace the $25 battery every 12 months.
With that programmable charger, you can simulate various panel output currents vs time for solar-insolation and see how well charged you are after a resting 4 hour period. Then discharge with your phone like a normal operation, and compare over a few cycles.
One of the most interesting lessons I have learned in the last 24 hours is that small SLA batteries are not all the same and that maybe I should be looking for a different type. I didn't really think about the deep cycle part of it. Obviously with solar, that is an issue.Leave a comment:
It is a decent multi stage electronics charger. I bought it at Fry's last week. $80.
I asked it to start at 1.5 amps. It was putting out 1.41 initially. An hour has passed and it is down to 650mA. I expect it will tail off to 100mA over the next few hours.
I buy my project parts here in California and take them to Australia. Parts are a lot cheaper here and the variety is a lot better. I go there often enough that I take them with me. A 10W panel I can fit in my checked luggage. Not sure about 20W. But big heavy things are expensive via unaccompanied air freight. It was going to cost $300 to send my 12lb assembly. Almost as much as it cost me to build it. It might be most cost effective to just continue with the small 10W panel and replace the $25 battery every 12 months.
Your resting SOC test sounds reasonable.
Be careful with the charger if it is a manual automotive type. You can do it if you are extremely careful, but most would recommend a 2 or 3 stage smart-charger designed to handle agm properly. With the panel and charge controller, it is just a simple CV limit - the battery bulks up to the CV voltage setting, and then because of that limitation, the battery will naturally drop current levels because the battery is not allowed to rise above the set CV voltage. What you are seeing is normal. The key to this recharging via solar is to be able to do it in the solar-insolation timeframe of your area. Othwerise, the batteries will always be in a state of under-charge (defecit charge), sulfate, and eventually fail to provide any meaningful capacity.
The reason I built my own pack with the Enersys Cyclon's is that they will take massive amounts of current so charge times can be really fast, which are important to me when I have limited amounts of solar-insolation available. I'm not limited to the C/4 maximum rate of the typical ups-style agm's, but START at C/4 with these. This ability to recharge very very quickly may not be needed in your case for something that only gets use once in awhile. I'm cycling stuff down to 50% daily more or less. I can get away with it on a small scale like this, but having the necessary amount of panel current goes impractically higher when you get to the larger batteries unless there is a real need for this fast-charge capability. Also note that the Cyclon's are very expensive compared to the typical Powersonic or UPGI agm's. I had the need for super-fast recharging - but it costs me in more supportive infrastructure.
In your case, the Cyclon's may not be justified.Leave a comment:
Okay the battery has been standing at room temperature for almost 4 hours. I took a reading and it measures 12.45V. So interpolating the scale given earlier, that represents 70% charge. I have now put it back on the charger at 1.5 amps initial current. We'll see how that goes.Leave a comment:
I'm now running 100 watts of panel into a 12v, 5ah agm - but it is a homebrew 6-pack of Enersys-Hawker Cyclon agm batteries, (two 6v monoblocs in series) where the cost of admission is a minimum current input of C * 0.4. This will have to do until Trojan makes a 5ah battery.Leave a comment:
You can get a rough idea by measuring the SOC voltage after a 4 hour rest of no-charge / no discharge:
12.8+ 100% charged
12.5 75% charged
12.2 50% charged
11.95 25% charged
11.95- don't go this low.
Without any test gear, what I might do for a quickie test is just use that cellphone charger if it truly does draw 280 ma for about 9 hours from a fully charged agm. You may have to use the phone a few times to recharge for 9 hours total. 280 * 9 = 2.520a, about 50% of that agm. Let it rest for 4 hours and measure the voltage. If you are nowhere near 12.2 volts, then either the battery is bad to begin with, or you didn't start out with a fully charged agm. Or the load isn't really 280ma constant.Leave a comment:
I have this one working out in a paddock on a farm right now with a 10W panel: SLA-12V7-F2
It has been running for 3 months. Here is a picture:
Am I going to have the same trouble? Low cycles?Leave a comment:
