If that's a general question for readers, I'll take a shot.
Look up the word "allusion". The no balls way to imply something in a way calculated to be able to more easily deny having said (wrote) it. Perception is everything.
Depth of Discharge under load
Speaking as one voice in California I have busted my pick talking to legislators about high power prices. I am now spending my time, labor and money reducing my cost of energy purchased from the grid. A few years ago in a different home my net cost per kWhr was $0.03. I used a combination of load shifting, solar power and a hybrid inverter with batteries.
I am still using the same batteries in another home where I hope to do the same and get enough life out of them to bring the total cost of energy purchased and generated significantly below $0.20 per kWhr and get bragging rights to being Net Zero. In the meantime I have had two power outages so the backup has had additional value. I also value the quality of life I have where I live in Northern California.Leave a comment:
I am still using the same batteries in another home where I hope to do the same and get enough life out of them to bring the total cost of energy purchased and generated significantly below $0.20 per kWhr and get bragging rights to being Net Zero. In the meantime I have had two power outages so the backup has had additional value. I also value the quality of life I have where I live in Northern California.Last edited by Ampster; 03-10-2019, 07:07 PM.Leave a comment:
This statement is straight out of the 90's
Where i live, electricity costs around 45c/kwh.
My off grid system is 6 years old and the electricity outputted has currently cost me 76c/kwh.
There are thousands of batteries just like the ones i use that have been cycled far more aggressively and are a few years older.
I'm confident my system will prove to provide less expensive electricity than my power supplier over it's lifetime.
Interestingly, the voices echoing what Sunking is parroting were a lot louder 5 years ago. In another 2 years they will be completely silenced.
It's just too bad the schools of today don't teach manners, and the difference between physics and economics.
Try to look at it from the perspective of most of the US. They would not stand for high electric rates and would work with their state governments to make sure batteries are not the answer to the problem.Leave a comment:
What you do not know is batteries cost money and have a negative EROI. Basically that means they will never give you more energy than was put into them to make them.
There is no way to win with off-grid solar. The law of physics will not allow it. To bad schools today do not teach math and science anymore.
Getting back to this statement..
How else am i supposed to look at a battery other than how many kwh i will be able to harvest from the sun over the course of the batteries lifetime?
That is the cornerstone of off grid power.
When you have off-grid power, you can only price your power as you go. ie: if your system cost $30k, the first kwh you use costs you $30k, when you have used 30000 kwh it has cost you $1 / kwh.
It is plainly obvious that the total energy throughput of a battery is the most significant factor in off-grid power cost.
I'd love to hear your reasons for viewing this differently!
My thoughts don't answer your fundamental question about the cornerstone of off grid power. However the technological improvements being demonstrated in the grid tie use of Lithium batteries may shed some light on the issue of how one might view this differently. If you believe that Lithium batteries are more efficient and that with proper management they can be discharged deeper and last longer than Lead Acid batteries then you have opened the door to a different way of viewing this issue. That is the bet that a lot of grid battery suppliers have placed and I tend to value their judgement.
I tend to look at large macro economic trends also and there are some interesting trends that may shed light on your question. I admit I am biased. I spent too many years on a sailboat nursing lead acid batteries and taking hydrometer readings. I also read with some alarm about the occasional explosions caused by hydrogen gas. I see Lithium as the preferred chemistry, at least for the big players in the grid support arena. I realize that may have drifted away from your fundamental question.
Those who draw some false equivalence between energy required to create a battery and the energy that passes through it (with some energy always lost in the process BTW) are looking at the whole thing incorrectly. Doing so is ignorant, incorrect and misleading, but suit yourself.
I suspected that was probably not true. The important issue was that the Australian grid was stressed and batteries came to the rescue. The initial Tesla grid battery has been followed by additional investments by others in more battery installs in Australia. Those are commercial installations. Is that correct?
I just wanted to point out that the coal powered stations din not fail in the heat.
Whether or not wind, solar and batteries will be cost effective, maintain reliable supply and save the planet will depend what the individual wants to believe.
The other thing that I didn't mention in my response to the earlier post by SunEagle was that the California Independent System Operator has authorized the payment to behind the meter batteries to put load on the grid. This is unique to California because public policy prefers not to curtail solar generation. There is already negative pricing in the wholesale markets a certain time because of the large buildout of solar generation. What that means is that the ROI of batteries in California is improved by this policy change in the retail markets.Last edited by Ampster; 03-08-2019, 10:34 AM.Leave a comment:
If you google "South Australia Blackout Cause" you get info on an event in South Australia in 2016 when there was a major power blackout.
The wikipedia page is possibly a good summary.
If your not interested in reading, basically there was a severe weather event causing a lot of damage, the wind farms were not happy so shut down overloading the supply from the next state and that then shut down.
After that Elon Musk offered to supply a battery.Leave a comment:
I agree, and the part of my comment that relates to peaker plants in California is all about the math. In that case spot pricing during the neck of the duck curve is very high and large grid scale short term battery storage is competitive. That is especially true because of the large growth in solar in California, it is cheaper for those installations to charge their batteries with solar than buy it from the grid. You probably don't see those kind of issues in Florida. Oddly for some reason in Australia the coal plants shut down when it gets real hot. So batteries are coming to the rescue there as well.
Will the cost of a battery system generate enough kWh over its life that is less expensive then purchasing the same number of kWh from your POCO?
I am sure someone can get a lot of cycles out of low cost batteries and can justify using them instead of purchasing a kWh for 30 cents or more but in reality the majority of battery systems will end up costing more then what you would have paid the POCO for the same amount of kWh because the average cost of a kWh from a POCO is less than 15 cents.
As far as using low cost batteries, my hope is that the increase of manufacturing capacity globally to support these large installations and the growth of the EV market will result in lower cost batteries. We saw that happen wirth the price of PV panels. I am not just talking about California or the US for that matter. I am looking at global trends in Asia and India as well.Last edited by Ampster; 03-07-2019, 04:35 PM.Leave a comment:
I am sure someone can get a lot of cycles out of low cost batteries and can justify using them instead of purchasing a kWh for 30 cents or more but in reality the majority of battery systems will end up costing more then what you would have paid the POCO for the same amount of kWh because the average cost of a kWh from a POCO is less than 15 cents.Leave a comment:
Detach the batteries, and you will have a very different story
Happy reading.Leave a comment:
Sunking. You do realise you have conveniently linked the batteries AND the attached vehicle to come up with 20 years payback time?
Happy reading.
