Charging 24v battery bank with 12vg
Here's another one - I have a high power, short duration demand for my electric outboard. Say 40 amps @24v for an hour pulled from two 12v 125AH AGM batteries. Then maybe no power requirements for a week. Rinse and repeat all summer. Do I still want a largish solar array ( 400+ watts)? Note: I'm in the PNW - a little sunnier than Seattle but not much. -
Trojan Battery
Rolls Battery
Morningstar.
VB has so many security flaws you can drive a truck through with no one noticing until it is too late.Leave a comment:
As a side note I should have thought about Genasun as they specialize in Marine and Golf Cart products which make them a Niche supplier and not many uses for them so they get tossed back in the closet of my mind. Their Boost Controllers are aimed directly at the Golf Cart market using a 24 volt solar panels as the roof to charge 36 and 48 volt batteries. Like I said if given a choice you want to go from Higher to Lower voltage aka Buck Converter which is what 90% of the Controllers use.
OK the main player in AGM is Concorde, but not the Military and Aircraft product lines. They make Sun Xtender (RE), Chairman (Motive), and Lifeline (RV & Marine). Another one with limited battery selection is Odyssey. Optima is like Odyssey in that they tailor to the Motor Sports and Utility Vehicle markets. Optima realy is not much of a player because of the small sizes offered only in BCI automotive case sizes. Odyssey at least make a few models large enough to be useful in small solar applications like an RV where you need a smaller battery with BIG PUNCH..
Best of the best is Concorde Sun Xtender line up.Leave a comment:
That answers my question exactly. I don't think I've ever seen that done on an internet forum. Thanks! Sunking has inspired a new line of thinking though and now I think I'll put all my eggs into a shore based charging station.Leave a comment:
You cannot post links, but I can. Genasun makes them and Marine rated. Their market is golf carts with these and at 24 volts limited to 200 watts input maximum.
As always if given a choice you go from higher to lower voltage. You have a choice.Last edited by Sunking; 11-07-2018, 08:10 PM.Leave a comment:
To answer your question directly - yes, there are boost converters that will boost a panel's 18 volt output to the ~28 volts or so needed to charge a 24V battery bank. And will do MPPT and everything. Can't post links here so google "boost MPPT controller."Leave a comment:
Fullriver has a full line of AGM Deep Cycle batteries. I've had real good performance from them.Leave a comment:
