Hi Russ,
Understood - both ways I'm sure.
Robert
golf cart roof charger
Robert - One more post like this and bye bye. This is the only warning.Really?
Your snarkiness didn't help one iota. I had to do my own research after you offered no usefull information. And might I say incorrect information.
Why are you posting here. You are wasting the time of many.
Psuedo experts like you are exactly the problem with internet forums.
Get a clue dude!
RobertLeave a comment:
Most of the golf carts in Florida are electric because they are easy to maintain and do not make any noise while out on the course. The only places I have ever used a gas powered cart is on a course that has a lot of hills and that was up North. The gas carts would be able to provide enough power to tool around a hilly course better than an electric cart but in Florida there really aren't that many golf courses with hills.
It is just easier to find and purchase an electric cart here then find a gas powered one but I understand why you have them in VA.Leave a comment:
wasted your time?
Really?
Get a clue dude!
Then why are you here asking questions? Your mind was made up before you asked any questions. Kind of wasted our time.Leave a comment:
electric golf cart
Valid question,
I received a very nice electric cart for almost nothing - family deal.
Doing a little customizing is a bad habit of mine, hence the solar project (and other items).
I just put a new set of 8V batteries in it for a little over $660.
The solar project will add close to another $1000 by the time a new roof is fabricated.
Does it make sense financially - probably not.
If I was out shopping for a cart, a gas engine would certainly be high on the list.
245W panel is arriving today. Materials to fabricate the new roof will arrive this week. I'll have to choose one of the step-up charge controllers.
Ebay LCD ammeter and voltmeter ordered.
A little welding and wiring and viola.
What is the appeal of an electric golfcart? My FIL has a gas one we use to putt around the property and it uses very, very little fuel. Why would one buy electric over gas considering the 1K battery replacement every 3 years or so?Leave a comment:
step up charge controller
Here is another step up (boost) charge controller:
http://www.solarconverters.com/index...1-cv-24-48-6pv
$219 from solarsellers.com
panels
Thanks Inetdog for actually reading my proposal. I would love to use more panels, but there is only so much room available above the cart. I do in fact understand the panel output on my RV as it is fully instrumented. My RV also sits for several days with only the single 260W panel providing input to the batts - it works great!Will work with one panel if he uses the specific boost MPPT CC he posted a link to. However I cannot give any evaluation or recommendation with respect to particular CC since it is new to me.
He will need to watch out for the limitation that it will only work reliably if the panel Voc never goes above the lowest voltage of a discharged battery bank.
That could be a problem for some grid tie panels, and even worse if he was using a 36 volt battery bank, which the CC also supports.
The cost of a 260w 12 volt battery panel will be higher than the cost of a 260w grid tie panel, but at least it will be within the operating parameters of that CC.
I am also an EE who understands the ramifications (and limitations) of the project. I also live in SoCal with lots of sun available. 350wH per day on a 260 watt panel is not a stretch. And if that gives me a mile of driving, I am pretty close to not using the charger often if at all.
The cart will also be instrumented, so I will know exactly how things perform.
I will happily report the results of my project (or failed project, to those who will read it that way) after the parts are bolted together.
That's about what I was going to say, build a roof frame to hold 2 or 3 GT panels in the 200w range, andWell I have done a few and the easiest best solution is to use 2 or 3 grid tied panels wired in series with a MPPT controller. As you know GT panels are half the cost of battery panels. To take it one step further he does not need to reinvent the wheel here as there are already golf cart roofs with the 3 panels already fabricated.
a Rogue or Kid MPPT controller. But for the expense, you will only get bragging rights for 1 extra mile a day. If it's only used for beer runs (load & unload) maybe it will keep the charge up, but it's got to be parked in full sun all day. Maybe some tilt (20deg) to the roof to improve the sun angle.Leave a comment:
He asked for the easiest best cost effective solution.
Well I have done a few and the easiest best solution is to use 2 or 3 grid tied panels wired in series with a MPPT controller. As you know GT panels are half the cost of battery panels. To take it one step further he does not need to reinvent the wheel here as there are already golf cart roofs with the 3 panels already fabricated. Problem is he does not want to hear any other solutions or experience. It is his way or the highway. So good luck. Just keep your regular cart charger because you are going to need it.Leave a comment:
When oriented correctly and in full sun you may get 50% of the 260 - normally you will probably get a small fraction of that.
I think you have no idea what the panel on your RV actually produces - you are just assuming while the RV alternator does the charging.Leave a comment:
The cost of a 260w 12 volt battery panel will be higher than the cost of a 260w grid tie panel, but at least it will be within the operating parameters of that CC.Leave a comment:
Not going to work with one panel.Leave a comment:
charging efficiency
Yes, that is why I am going to build a golf cart roof around a 260W panel. That's a lot of power.At my old job they purchased a golf cart with a solar roof. It was supposed to provide all of the power needed to keep the batteries charged. Big disappointment. The panel barely provided a trickle charge when it was stopped under full sunlight. They had to charge the batteries at night the conventional way with a standard charger. It seemed to be a nice idea but did not pan out as expected.
I have one on my motorhome and never have to run the generator anymore. I sometimes see 18A coming off the panel (at 12v).
This would correlate to 4.5A at 48 volts which doesn't sound like a lot of charging power. However if the cart sits idle 90% of the time,
it should certainly stretch out the charge duration. I guess I will find out!
