Off Grid RV- just need some LIGHTS!!!
thanks for the info
H = Hours
A = Amps
AH = Amp x Hours
So from that knowledge you know:
H = AH/A
A = AH/H
So lets say you have a 100 AH battery and apply a 5 amp load. So H = 100 AH / 5 Amps = 20 hours. However if you fully discharge your battery you do serious damage to the battery. To maximize battery life you only want to use about 20% of the battery capacity. So for that 100 AH battery, only 20 AH is usable so with that same 5 Amp load is just 4 hours.
Now with that said if the battery is only for emergency use you can discharge down to 50%. You give up some cycle life, but batteries only have a limited shelf life so if used only occasionally no harm discharging down to 50% because it will be worthless by the end of its shelf life anyway. So 50% of 100 AH is 50 AH so that same 5 amp load can be applied for 10 hours.Leave a comment:
Struggling with solar, but want lights for backup lighting at home!
What think ye?? Working on solar, but cannot get act together right now regarding solar. BUT want home backup NOW.
I have 2 sets of 2 each auto DC LED lights, for a total of 4 lights. Each set of 2 draws 5 amps. Just want lighting, have plenty of other supplies. Can someone give me the figures on this: 114amp@1hr marine deep cycle batt, thinking about getting 2nd esp if needed. Want to charge on grid, NOT SOLAR. Wud like to leave hooked up to elec. so when elec goes off, I can switch to batt power. There R U guys out there that know your stuff! Your advice please!!!!Leave a comment:
Rayovac Sportsman xtreme SE3DLN = 3 D cells. (300 lumens broad beam output)
These are cheap enough to see if you could actually stand living with them before wiring up a solar system. The cool color temperature of most led lights can sometimes be too depressing in the long run, and some may have an unsuitable beam indoors. Since both products can run on internal batteries, you can do a test-run first.Leave a comment:
Yep $1500 for some lights is crazy, better off getting a low power system like the ones I previously linked to.Leave a comment:
Well that would be a good idea. When you do you might just see it does not add up and start to wonder what all the hype is about.Leave a comment:
Its for indoor lighting, and some outdoor lighting if possible. Maybe a small fan on the inside. I just need to figure out the math on this stuff.Leave a comment:
why?
Why do you want to spend $1200 to $1600 for some simple security solar lights?
Maybe I don't understand your final usage? Because that is serious over kill for some security lightingLeave a comment:
Found this link also. But does not include batteries.Leave a comment:
Ah, ok, so around $1200.00 should do it for a basic setup, I guess that's what to expect. So not this year.
Ive seen some LED lights that are replacements at 1 volt or watt. They just cost $30.00 a piece.Leave a comment:
You can always just cannibalize them for parts, but most are designed to run off 1-5 volts, so connecting them to a 12 volt panel and battery system would not be economical.Leave a comment:
Anything sold by horrible freight (or is that fright) that is useful for anything other than a boat anchor?Leave a comment:
