Help with batttery system
Nope, don't see any UL Listing, the search continues I guess. -
Let's get some simple math out of the way and help you understand. It is 5th grade math and super easy
Starting with Amp Hours = Amps x Hours. Told you it was hard.
From that equation then you know:
Amps = Amp Hours / Hours
Hours = Amp Hours / Amps
Using simple numbers let's say you have a 100 AH battery. You want to discharge it at 10 amps. How many hours does it take to discharge it. 100 AH / 10 A = 10 Hours.
Want to charge that battery from completely discharged with a 10 amp charger. How many hours will it take. 100 AH / 10 A = 10 Hours.
How many Amps can that same battery last with a 5 Hours discharge rate? 100 AH / 5 H = 20 Amps
Unfortunately life is not that simple. Batteries are not 100% efficient and Mr Peukert Law gets in the way. Not to worry what is above gets you the idea.
Next problem you run into is batteries have minimum and maximum charge rates. A FLA battery minimum is C/12 and maximum is C/8 generically. C = the battery AH capacity at the 20 Hour discharge rate. So those 225 AH batteries need at least a 225 AH / 12 H = 18.75 amps. Just call it 15 is close enough. The maximum is 225 AH / 8 H = 28.125 amps. Just call it 30 amps is close enough. So you now know you need something in the 15 to 30 amps. But there is a Gotcha. It you go with 15 and want to use power while charging, you are robbing the battery of charge current. If your load is 30 amps and you have a 15 amp charger, you are still discharging your battery at 15 amps. Gotcha!
On the Flip Side Batteries have a Maximum Discharge current they can provide otherwise their voltage will sag to far and cause unnecessary Low Voltage Disconnect built into all Inverters. For standard FLA battery that is about C/8 or 30 amps on a 225 AH battery. So if your limit is 30 amps limits how large of an Inverter you can run. So you want to run 24 volts x 30 amps = 720 watts. Not a good match for a 1000 watt Inverter.
Don't cuss there is a work around. Use a hybrid FLA or a more expensive AGM battery. Buy Golf Cart FLA batteries, as they are Hybrids. A Golf Cart battery can handle C/4 Discharge currents so a 225 AH battery can supply up to 225 / 4 = 56.25 amps, just call it 60 amps. At 24 volts x 60 amps can handle a 1500 watt Inverter so a 1000 watt 24 volt Inverter is no problem.
This brings us back to a battery charger issue again. You do not need a 3-Stage Battery Charger for Emergency Back Up. You do not even want one for that application. You want a FLOAT CHARGER of the appropriate Amperage Capacity. You will leave it plugged into commercial AC keeping the batteries fully charged waiting to be used. You want it to be as large as a standard 120 VAC wall socket can supply and your generator. a 120 VAC circuit in your home can supply 1500 watts continuously. So for a 24 volt battery charger you are looking at a 60 Amp 24 volt charger.
Now just go over what we just did and look at how the pieces fit together in harmony.
You are looking at needing a:
1800 watt genny. check
24 volt 60 amps FLOAT CHARGER. Check
4- 6 volt 225 AH Golf Cart Batteries wired in series. Check
1000 Watt TSW Inverter. Check
Fits like a custom tailored shirt made with Warm Fuzzy.Leave a comment:
Is this it?
If so you do know that is 12 volts right? I thought were were discussing 24 volts?
Here are some for Marine apps
Another oneLeave a comment:
Found this at Amazon... "Progressive Dynamics (PD9260CV) 60 Amp Power Converter with Charge Wizard.... Its $200, seems too cheap to be true. Could this possibly be any good??Leave a comment:
No problem Steve, i twill work. I just want to make sure you understand what you are doing and giving up.Leave a comment:
Lot cheaper than PWM. With PWM you are forced to use very expensive battery panels costing $2 to $6 per watt. With MPPT you can use higher voltage Grid Tied panels costing $1 per watt. It takes a 300 watt PWM system to equal a 200 watt MPPT system. A 300 watt PWM system is going to cost you roughly $600 to $700. A 200 watt MPT System roughly $400 to $450.
That same Morning Star 60 amp controler is $516 at Ebay. So just to clarify..I can charge batteries with grid power or jenny with this type of device and it will also handle power coming in from panels? Would you recommend anything besides the Midnite Solar Classic, which was more like $800 where I looked. As to the jenny question overload question, I hadn't seen your 1800 watt comment, no problem
$572 is too much for a 60 amp controler. Top of the line is Midnite Solar Classic 150 is a 90 to 96 amp controller for $600.
How did you come to that conclusion? A 60 amp 24 volt charger would need a 1.8 to 2 Kw generator. To get the most out of your fuel you want to run your genny up around 70 to 80% fully loaded. Running 30% is going to burn up a lot of fuel.Leave a comment:
A goggle search turned up this at Amazon, MorningStar TriStar TS-60 Amp Solar Battery Charge Controllerits, $572 Yikes, This project is spiraling outa control but I think I'll carry on because panels may be added later. If I had to bring the batteries back to full charge with my "big" 5KW, generator that might be a problem?
edit, Oh, I see your 1800 watt for the gen set. Do these chargers put out max amps at first then drop off easing the load on the jenny? and if I did get a few panels they would be hooked up to this charger, max 3KW? I'm trying to justify the $ Thanks again for the help.Leave a comment:
Are you able to afford a GOOD charger, or do you have to just get by ?
The larger inverters can also be used as chargers from the generator, I know the XW series does this (that's what I use) and I think outback can do it too.
Stand along chargers, Iota has solid ones, but they have poor power factor.Leave a comment:
Greetings. I have been trying to gain a little knowledge and set up a battery system, without panels, at least for now. I'm on the grid and use this system during power outages. I understand that using four 225 amp in series for a 24v system would be better, although way more spendy, than a 12v system. I have a 2.9 KW gen head powered by a 4&1/4 HP Lister SL1 and a 5KW ST head powered by a 8.5 HP Lister SL2. Only one gen set at a time can be run, Not allot of power. I'm aware that I need a good 120v three stage 24v, charger but I don't want to put allot of strain on the gen set if I need to charge the bank before grid power is back up. I'll need to run the them for the well pump, shop tools etc when needed, every tow or three days+-...I am considering a 24v 1000 watt Go Power inverter to send the power to the six circuit transfer switch in the house. My needs in the house dont amount to 700 watts with all the lights TVs, DVRs computers and both small reefers all running, checked everything with my "watts up" meter. So considering the small gen sets and the fact that "run time" really isn't an issue, what 24v charger would be a good choice. I dont quite understand figuring out amps and time required for charging and how that relates to battery health. I am grateful for the help I've already gotten, as was told to me "ask questions first"
