Moderator note.
WE ARE watching this thread (along with the NSA that watches everything - hi Mom!)
It's become a real hoot! As long as you keep it civil, and stop the name calling and insults (I'm going back and will start pruning pointless content out), the discussion (in my mind) should be allowed to continue.
But we are aware you are cherry picking data, comparing apples to oranges, and neophytes beware, there is a lot of misdirection going on here, do not use this conversation as your sole source to chose a battery bank.
LiFePO4 vs Lead Acid a cost analysis for energy storage.
Have you read the entire article or select only what you want to see.Read that a dozen times over the years and says exactly what I have stated. A lithium uses a Constant Voltage Current Limit algorithm. I love using your own articles against you. It makes it easy.
"The Li‑ion charger is a voltage-limiting device that is similar to the lead acid system. The difference lies in a higher voltage per cell, tighter voltage tolerance and the absence of trickle or float charge at full charge. "
Which means when the Charge current tapers off to C/20 it must be terminated or you will damage the cell. It is the exact same CV algorithm as lead acid. The difference is you must terminate a lithium charge and not allow it to float like you can a Lead Acid to keep topped off.
Of course in most applications LiCoO2 is charged in two stages first CC then CV but if you remove the CV part you improve the battery life with just little effect on total capacity 15% less.
Of course LiCoO2 is used in mobile device where those 15% are a huge deal and battery life not important is good enough for 3 years obsolescence.
On stationary application that is a totally different story.
As for LiFePO4 that is a hugely different battery from LiCoO2 in almost all aspects and that charged with just one stage CC will provide you with 95% SOC so only 5% loss with a good improvement in battery life.
See this part of the article
"Li-ion does not need to be fully charged, as is the case with lead acid, nor is it desirable to do so. In fact, it is better not to fully charge, because high voltages stresses the battery. Choosing a lower voltage threshold, or eliminating the saturation charge altogether, prolongs battery life but this reduces the runtime."Leave a comment:
When you size a battery you need to take in to account battery efficiency. Maybe it can be overlooked for a battery with 95% efficiency but not for one with 75% or less.
Do you have some graphs somewhere with the charge discharge of your battery? How deep it was discharged for that 75 to 80% efficiency? And what was the charge / discharge rate?Leave a comment:
Read that a dozen times over the years and says exactly what I have stated. A lithium uses a Constant Voltage Current Limit algorithm. I love using your own articles against you. It makes it easy.Read this article
http://batteryuniversity.com/learn/a..._ion_batteries
Read this article
Figure 1 shows the voltage and current signature as lithium-ion passes through the stages for constant current and topping charge. Figure 1: Charge stages…
CC can be dose even for LiCoO2 with a bit more loss in capacity than LiFePO4 but with the same positive effect in prolonging the battery life and that is what you want for stationary energy storage.
Using CC only up to 4.2V with LiCoO2 will get you 85% SOC but improved cycle life by much more than 15% witch will make for a better price/kWh stored even much better if you stop at 3.9V 8x increase in cycle life wile still having 70% SOC that will get you 5 to 6x better price/kWh during lifetime.
For LiFePO4 is way better if you do CC up to 3.6V and stop there you have over 95% SOC depending on battery manufacturer there is a small variation. And with only CC you prolong the battery life so is no brainier in stationary application where energy density is not important.Leave a comment:
There is no much difference in Lead Acid batteries. That was just one article there are plenty of them and all state that charge/discharge efficiency is around 50 to 60% in typical storage applications since you use only the top 20 or 30% and that is where any Lead Acid battery is the most inefficient.Yeah 10 years ago. Did you read it and understand. The model is completely irrelevant. They used a single 12 volt antiquated battery (Trojan 30xhs)with freakisly low charge rate of C/33 something you would never do on a solar PV system. Apparently you have selective reading skills right from your own document:
It is generally understood that battery charge
efficiency is high (above 95%) at low states of charge and
that this efficiency drops off near full charge.
In the conclusion they sum upped:
The greatest output was 96.5Ah, which resulted from
116Ah input.
No matter how you slice it comes out to 96.5/116 = 83% efficiency from 0% SOC to 100% SOC. Take a lithium to 0% SOC and you have a boat anchor. I do not sell batteries or chargers like you do so I don't have a bias.
About selective reading skill "95% at low SOC" but did you watched the graph low SOC is well under 50% where you are almost never use the battery not relevant.
Simple experiment since most of you have Lead Acid in offgrid installation. Measure the discharge power after battery is full 100% SOC and then charge the battery back to full and see what is the difference between what you took from the battery and how much you needed to put back to make that 100% SOC again.
I bet it will be around 50 to 60% efficient at best.
And this will be real word data no lab test.
Some of you must have the equipment and necessary knowledge do do this data log.Leave a comment:
You got a lot to learn about lithium batteries and charging algorithms.You will not want to float a LFP those that do so is because they use Lead Acid chargers and have no choice not the proper way.
You can float LFP without much damage under 3.4V / cell
The correct way is to charge to 3.45V or 3.5V and at that point stop the charger is charging is done at 0.3C then you have at that point more than 95% SOC not worth going higher since you only degrade the battery.
We call that a One Trick biased Pony in engineering.Leave a comment:
Maybe, but I doubt it. Lithium will win the EV market only because of Specific Energy Density which is critical for motive power but meaningless for RE and energy storage. Smart money is on Lead Carbon Acid batteries. Same low price as lead acid, 20,000 cycles to 100% DOD. Lithium cannot touch that.My prediction for the future (I think this is my first ever prediction) is that LiFePO4 will be as wide spread for grid and offgrid energy storage as the Lead Acid is now.
That is unless another even better chemistry still based on Lithium will compete with LiFePO4
Educating people will take some time so I can not say for sure when will this happen but I think in less than 5 years before 2020
There are a few smaller companies that prepare something similar with my Solar BMS and they will be available starting next years.Leave a comment:
116Ah input.
No matter how you slice it comes out to 96.5/116 = 83% efficiency from 0% SOC to 100% SOC. Take a lithium to 0% SOC and you have a boat anchor. I do not sell batteries or chargers like you do so I don't have a bias.Leave a comment:
If you want to advertise Lead Acid you may say that. Did you read the article above about charge efficiency vs SOCNot even a remotely true statement. Lead acid charge efficiency runs from as low as 80% up to 97%. Depends on type, plate material, VRLA, and plate construction. You gotta a lot to learn. AGM efficiency is 95 to 97% with very little Peukert effect. Nickel chemistries have the lowest charge efficiency, Lead is depending on type is in the middle or near the top from 80 to 97%.
And how may use the more expensive VRLA for energy storage instead of deep cycle flooded?
LFP for energy storage uses only CC charging where it gets to 95 to 98% SOC the rest of 3 to 5% will be detrimental and is not used in most applications.Dead wrong, LFP or any lithium chemistry uses CV current limit algorithm. or put another way is Float Charged.
LFP can be charged as high as 1C so for say a 10 AH cell can be charged as high as 10 amps, as the cell voltage reaches the charger voltage of 3.6 volts the current tapers off and voltage is constant at 3.6 volts until the charge current tapers to C/20. At that point the charge is terminated. If not terminated the battery is damaged unlike lead acid. You can leave lead acid on Float to eternity as every utility company does. Exact same algorythym as the Absorb and every Float charger made. Only difference is the set point voltage.
Charging characteristic of LiFePO4 is quite different than LiCoO2
Also charging with more than 0.3C on most LIFePO4 is not recommended for energy storage applications and not needed for stationary solar charging.
A electric car has quite different requirements.
I know enough about batteries at least about the one I care about LiFePO4Only thing charge efficiency effects is the size of the panel wattage. Discharge rates with FLA by design are C/20 or less so discharge efficiency or Peukert effect is not an issue. Short burst of a microwave oven are not enough to effect Peukert Law to come into play. Now if you want to talk EV's, that is another animal where Lithium can be justified. But lithium cannot be justified for RE as of yet. Prices and cycle life are not there yet.
If you really want to know about batteries I suggest you join IEEE and buy their battery documents. I set on the 450, 946, and 1660 committee. Another good book is what I call the Battery Bible aka as the Handbook of Batteries 4th Edition written by Thomas Ready which is state of the art battery application covering all chemistries.
And I know about Lead Acid since I investigate them for my offgrid house. I'm glad A123 System advertised their first battery at just that particular moment it was the first time I heard about LiFePO4.
Dead wrong, LFP or any lithium chemistry uses CV current limit algorithm. or put another way is Float Charged. LFP can be charged as high as 1C so for say a 10 AH cell can be charged as high as 10 amps, as the cell voltage reaches the charger voltage of 3.6 volts the current tapers off and voltage is constant at 3.6 volts until the charge current tapers to C/20. At that point the charge is terminated. If not terminated the battery is damaged unlike lead acid. You can leave lead acid on Float to eternity as every utility company does. Exact same algorythym as the Absorb and every Float charger made. Only difference is the set point voltage.A lot of that loss is transformed in heat and breaking the bond between oxygen and hydrogen.
There is also another aspect that is the way Lead Acid is charged where at the top of the charge you are usually not using the available current from the PV array since you need to keep the voltage constant and reduce current usually by simple PWM. This is not the case with LiFePO4 where you only charge using CC there is no CV charge needed.
If you really want to know about batteries I suggest you join IEEE and buy their battery documents. I set on the 450, 946, and 1660 committee. Another good book is what I call the Battery Bible aka as the Handbook of Batteries 4th Edition written by Thomas Ready which is state of the art battery application covering all chemistries.Leave a comment:
I did not wanted to mention MPPT since that is an obsolete technology at 1$/Watt for solar PVJust for completeness (and pedantry):
1. An MPPT CC can take partial power from the panels and still deliver relatively constant current to the battery in Absorb and Float as long as the PWM is happening at the input to the DC/DC converter. So pulsed versus steady current charging is not necessarily an issue.
The idea was that it can not use the total PV power even when Battery is not full.
LFP will not use PWM when is 95 or 98% charged you just stop the charging and is true that there can be during the day and still be power not used from the panels but that is a different story that lost power is just 3 cent /kWh2. Possibly a misleading comparison since LFP charging can still use PWM to maintain the desired current and whether you use 50% of the panel power 100% of the time or 100% of the panel power 50% of the time the result is still that you will not be able to use all of the PV power effectively for battery charging.
You better have wasted power from PV than generator 3cent/kWh vs at best 1.2$/kWhIt is a valid point that delivering Float charging to FLA via PV can be a particularly bad waste of panel power, or an even worse waste of generator power. Sunking has some recommendations about setting Bulk, Absorb and Float voltages that recognize this difficulty and maximize the amount of PV that you can capture.
I do not have a generator for my offgrid house and never considering getting one.
In stead as a backup I have a 0.5kWh LiFePO4 (A123 systems) with 2x85W PV panels (this is a separate circuit from the main one) and extremely inexpensive to have. I only used this backup one night last year my fault at estimating the main battery charge. It will not happen when I have an SOC indicator.Leave a comment:
Just for completeness (and pedantry):There is also another aspect that is the way Lead Acid is charged where at the top of the charge you are usually not using the available current from the PV array since you need to keep the voltage constant and reduce current usually by simple PWM. This is not the case with LiFePO4 where you only charge using CC there is no CV charge needed.
It is a valid point that delivering Float charging to FLA via PV can be a particularly bad waste of panel power, or an even worse waste of generator power. Sunking has some recommendations about setting Bulk, Absorb and Float voltages that recognize this difficulty and maximize the amount of PV that you can capture.Leave a comment:
They are every where mostly in the datasheets of battery manufacturers even if not presented directly in this way (not a good way to advertise).
Most power is used by large devices usually that produce heat like cook-stove, microwave ... they use a lot of power for relatively short periods of time so the discharge rate of that battery is quite high even with large battery banks.
The flooded Lead Acid usually has the worse efficiency but other are quite bad also.
You can read this study but there are plenty of informations all over the web regarding charge/discharge efficiency. If you have better informations about charge discharge efficiency please provide a link
Here is the conclusion in this article
A test procedure has been developed to allow the
examination of battery charge efficiency as a function of
battery state of charge. Preliminary results agree well
with established general understanding that the charge
efficiency of flooded lead-antimony batteries declines with
increasing state-of-charge, and that charge efficiency is a
non-linear function of battery state-of-charge. These
tests indicate that from zero SOC to 84% SOC the
average overall battery charging efficiency is 91%, and
that the incremental battery charging efficiency from 79%
to 84% is only 55%.
This is particularly significant in PV
systems where the designer expects the batteries to
normally operate at SOC above 80%, with deeper
discharge only occurring during periods of extended bad
weather. In such systems, the low charge efficiency at
high SOC may result in a substantial reduction in actual
available stored energy because nearly half the available
energy is serving losses rather than charging the battery.
Charge efficiencies at 90% SOC and greater were
measured at less than 50% for the battery tested here,
requiring a PV array that supplies more than twice the
energy that the load consumes for a full recovery charge.Leave a comment:
