It will be painted. I would think that a quality paint job would protect it adequately.
What do you think?
Question s regarding mounting panels on a curved roof?
And you will have less of an issue with galvanic corrosion if you use aluminum.Last edited by Ampster; 04-08-2019, 10:23 AM.Leave a comment:
The steel Unistrut is very heavy, especially so for the larger rectangular type. If the aluminum version of Unistrut is available you might want to consider it.Leave a comment:
I do know that solar panels have venting at the rear, I am guessing their output increases or at least there is less drop in output? I am seeing so many boats with the flexible versions glued to curved cabin roof and decks, I would reckon if you calculate your needs you may still cover your usage? If it really is as simple as it appears then your mounting problems are sorted at the stroke of a brush dipped in adhesive?
DaveLeave a comment:
[QUOTE=Ampster;n395386]They make unistrut or equivalent in a profile that is rectangular and therefore higher than the square profile. I got mine at McMaster Carr.[/QUOTE
Thank you.
I will check it out.Leave a comment:
They make unistrut or equivalent in a profile that is rectangular and therefore higher than the square profile. I got mine at McMaster Carr.Leave a comment:
Here we go...Attached FilesLeave a comment:
Sounds like you're not too mechanically inclined or imaginative. You were asking for a way to approach mounting to a curved roof and I gave you a perfectly viable option. Nobody seemed to be offering solutions. Fact is, if I had this situation I very likely would create some trusses cut to the curvature of the roof. And I'd leave the duct tape out of the equation.
BTW When I clicked on your link in the first post it took me to the home page of that site, not whatever photo you are eluding to.
I checked the link and it works for me...... Can anyone else see it?Leave a comment:
Depends how good you are at interpreting redneck engineering drawings.
Otherwise, I'd use one definition as a guide: Duct tape == hundred mile tape. As in: That's how long it will last when used in vehicle repair.Last edited by J.P.M.; 04-06-2019, 11:36 AM.Leave a comment:
BTW When I clicked on your link in the first post it took me to the home page of that site, not whatever photo you are eluding to.Leave a comment:
Any thoughts on the method shown in the picture I linked in the first post?Leave a comment:
