Pnpmcnab,
I think I need to do something like you have set up, but I'm not sure exactly what that is. From reading the other thread I believe you take 60V panels, send that PV through your unavailable CC and convert it to 60V AC which raises your water tempature not to 60F, but raises you're water temp by 60F, so from 50F to 110F?
I checked my specs and my water heater does not have a 2nd port IIcould put a DC thermostat in to Although I might be able to put it in a extra incoming water port but it's 3/4 NPT so I don't think the 1" NPT DC element with thermostat will fit so I really don't think this is an option?
This leaves me having to configure a way to use the existing AC element for heating the water. My current AC element is 120V 1650W. So how do I take the current PV output or my DC output and convert it to use with the AC element & thermostat?
If I ran the existing element at 60V that would give me 412W which is enough to heat the water. I'm just not understanding how to go from what I have now to the AC element?
I did see the techluck converter thing but it's pricy and from people on that thread have said it seems a like dangerous.
http://techluck.com/index.php#buy
I also saw the PMW CC set up to run a WH but that's as much as the MPPT CC have now
