To be honest if your trips are 3 days or less, you do not need solar. All you need is batteries, Inverter, and charger. Save the cash. Just conserve energy like turning off the Inverter when not being used. You can even run a line from the Alternator and an Anderson Connector to use the alternator to top off batteries while you drive. ! hour engine run time is 2 or 4 days of solar. Think before you jump in.
One issue you'll find on this particular forum is that people will only recommend top of the line equipment, and scream bloody murder if you diverge from the absolute perfect setup. That's a bit silly when installing in an RV, especially given that you describe your rig as a "hillbilly toy hauler". Furthermore they vastly over complicate things, and a specialty of this forum is either talking people out of installing solar or talking them into building vastly over priced and over spec'd setups. I'm of course not saying you shouldn't do everything to keep your setup safe, but you don't need top of the line equipment to be safe.
I just did a similar build to what you're contemplating and couldn't be happier with it. Here's my equipment list:
- Pick up one or two big 60 cell panels, which are in the 250 to 300 watt range. You could also get 72-cell panels, but then your voltage might go over 100 watts on cold mornings, which could fry your charge controller. Sticking with 60 cell panels keeps you safe there.
If you shop around a bit you should be able to find 60-cell 250 watt panels for about $150 each if they're demos or cosmetic defects or $210 or so new. Wire them in series unless you anticipate having one of the panels shaded occasionally, in which case you'll want to wire them in parallel (a bit less efficient but hey it's an RV).
- I have and highly recommend this charge controller. Its a few hundred dollars cheaper than the Morningstar and works beautifully.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
One thing to note is that it's 100 volts, so if you're planning on possibly using 3 solar panels in series now or in the future you might consider getting the 150 volt version:
https://www.amazon.com/SolarEpic-Cha.../dp/B00YCI48F4
But you can easily run two 250 watt @ 36 volt solar panels with the cheaper version.
I recommend getting the external monitor box at the above link too, it's only $30 and is very handy for seeing the status of your panels.
- get some 10 or 12 gauge wire to run from your panels to your charge controller.
https://www.amazon.com/Black-Gauge-S...ICM/ref=sr_1_4
For batteries, as recommended above get 2 6-volt batteries. You can't go wrong with Trojan T105's. Wire the batteries in series for 12 volts. If you want more capacity get 4 of them. Personally I still wire them for 12 volts to keep things simple, but there's good reasons to wire them for 24 volts. But keeping it 12 volts means you can use your existing 12 volt inverter, removes the need to step up the voltage from your alternator, removes the need to step down the voltage for your cabin etc, and 12 volts works just fine.
For your fridge, as others have recommended get a propane fridge. They work fantastically well and are available cheaply used. They still take a tiny amount of 12 volt power to run the brain but it's negligable.
And if you wire your panels in parallel, get some of these fuses (or a combiner box if you want to spend 10 times as much on the Cadillac route):
https://www.amazon.com/dp/B019YP0HQ8..._Y1oezbEV0ZKE0
And if you're wiring your panels in parallel you'll also need these or these.
And for flat mounting your panels to the roof of your RV, these work well.
