Sparkletron, I'm the OP, and I'm also revisiting this old thread. I use the GV-5, which has a default LVD voltage of 11V and reconnect voltage of 12V.
Regarding a battery sink, I found that a DC-DC buck-boost converter prevented the Bioenno low C disconnect, but I could not find one that was suitable for my application. One was quiet enough, but did not produce enough current. Another produced enough current buy was too noisy. It became clear to me that finding a regulator was going to take a long time. I considered trying to develop one based on a TI reference design, but decided instead to build my own LFP battery. That battery works great with the Genasun controller. And as I learned recently, so do Bioenno batteries.
Bioenno changed their BMS some time after 2015, the year I bought my first LFP battery from them. They no longer disconnect near end of charge when paired with a controller sold by another manufacturer. So, although I learned a lot about solar charging in this thread, it contains a lot of outdated information. If you are considering pairing a Bioenno Power battery with a Genasun charge controller, know that they are now compatible and no battery sink or any other workaround is required.
This thread has gotten a fair number of views over the years, so I wanted to set the record straight.
MPPT solar controller and LiFePO4 battery for backpacking
At the risk of raising ire over reopening this old contentious thread, I also had difficulty getting Genasun and Bioenno to work well together. In my case, a series of cloudy days would run my system down to the point where the battery's LVD would kick in. Once this happened, the Genasun no longer saw the battery and would therefore not charge it even after the sun returned. So basically my system couldn't automatically recover, and I had to manually jump start it to get the battery charging again.
My solution was to use a separate LVD to keep Bionenno's LVD from ever kicking in. As I write this, there are few LVD's designed for LiFePO4. The disconnect/reconnect settings are just too low. Fortunately, WMR's PWRguard PLUS allows you to set these values to whatever you want. So if you never want your Bionenno discharged more than 50% (perhaps around 12.85V), you can do that.
The PWRguard is small and light and compatible with the OP's backpacking scenario. It might help. While it duplicates what both the Bioenno and Genasun do, it does so in a way where you have complete control. For example, the GV5-Li-14.2V's LVD disconnects at 11.0V and reconnects at 12.0V. Those values are far too low to be useful! A Bionenno is essentially spent at 12.2V.
Now I understand that the OP's issue is not LVD, but the battery's BMS disconnecting itself (or not accepting any current whatsoever) from the Genasun when it's full, causing the Genasun's load output to rise to Voc. My point is simply that just because these products come with certain features, doesn't mean you can't reimplement them on your own terms. I don't agree with some who say you shouldn't buy a battery with a BMS-of-last-resort. Sh*t happens, and I can't tell you how many times the Bioenno's BMS saved itself.
I agree with those who say that if the Genasun always requires a battery sink, then just give it one. It could be a voltmeter, ampmeter, multimeter, LED, whatever. Check this out. Or you can use a DC-DC buck converter on the Genasun load terminals to ensure that the voltage doesn't exceed 14.8. Something like this. All of these solutions introduce inefficiencies and are not ideal, but it's what we have until more flexible solar controllers are available.Leave a comment:
The battery just needs to stay connected PERIOD. . . . It requires the battery to turn it into a VOLTAGE SOURCE so the Controller can regulate the voltage.
Back to Current Sources. Makes no difference is the Current Source is from a Voltage Source or Solar Panel, if you open the load, the voltage goes to the source voltage. A Solar Panel is a Current Source and the controller has a huge capacitor at its output. Your own eyes have seen what happens when the battery is disconnected. Your eyes are not lying to you.
Any MPPT controller out there is nothing more than a smart buck converter. And buck converters can go to zero output, and they do not need a battery (or a load) to regulate voltage. Any basic book on SMPS design will tell you this.
Just to provide an illustration, I connected an off the shelf 60 cell panel to a Midnite Kid and connected the output to an 8 amp hour gel cell. Turned it on and the battery quickly went into absorb at 13.96 volts, drawing about 2 amps. Input was 34.8 volts. Noise was 112 millivolts peak to peak. Then I disconnected the battery. Output voltage went up a few millivolts to 13.99 volts and the noise went up to 216mW (after losing that great battery "filter.") Input voltage rose to 36 volts as the panel unloaded. Output voltage stayed rock steady at 13.99 for an hour as the meter was reporting 0.0 amps out.
So no, you don't need a battery to "turn it into a voltage source." And no, if you open the load, the voltage is not required to go to the source voltage. When a current limited voltage feedback SMPS is in current limit, it is a current source. When it is regulating voltage, it is a voltage source. When it is open circuit (i.e. no load, no current) then it is by definition not in current limit so it is a voltage source.
You just make all this stuff up, exactly the same as you made up what you thought was inside a Bioenno battery. The link you gave to the "TI LM5019MR 100V, 100mA Constant On-Time Synchronous Buck Regulator" in post #132 has nothing to do with MPPT controllers, it is a low current buck mode power supply which only supplies 100mA, hardly suitable for an MPPT controller.Leave a comment:
Simmon Mathews is a salesman of cheap Chi-Com consumer electronic junk, and sales to suckers in Australia.Leave a comment:
The current doesn't come to a complete stop, it reduces to the leakage current of the battery plus any current drawn by the BMS circuitry. For LFP batteries without any BMS this is virtually zero.
The solar controller will actively adjust the current output to keep the voltage at the set point.
The equilibrium you are talking about here is the equilibrium between the SOC of the battery and the voltage. At a voltage of 14.2V when the charge current has tapered to zero the battery might be at an SOC of 99.5% whereas at a voltage of 14.6V the SOC will be 100%.
When the current being supplied to the battery is virtually zero the voltage from the solar panel at the input of the solar controller will be close to the Voc of the panel. It will not be Voc because of the current being used to run the controller electronics.
Simon
Okay, thanks. This answers my final questions. Thanks again for all of your help.Leave a comment:
Sunking, if I understand you correctly, you're saying that at CV, current comes to a stop, and voltage simply remains at that voltage ("set point" is s new term which I think equates to CV voltage). My question is what keeps it there? I think you must mean that either: 1) the set point is equal to the "full" point of the battery, so that the system comes to some sort of equilibrium with no current flow; 2) the controller actively sets current to 0A; or 3) self discharge makes it so that current flow never stops. If the CV voltage of a controller is 14.2V, and the saturation point of a 4-cell LFP is 14.6V, then if there was such a thing as "equilibrium" in an electrical circuit, then the system couldn't be at equilibrium at 14.2V, right? If the controller actively stops the flow, then by Simon's illustration, the "pressure" on the controller would be panel Voc, right?
SimonLast edited by karrak; 05-03-2016, 12:36 PM.Leave a comment:
The king of battery IC's is Texas Instruments, If you look back I gave you a link to the most popular TI IC used in MPPT controllers, and there are dozens of designs out there on the internet with the chips. However here it is againa 24/12 volt, 20 Amp MPPT controller using a TI MSP430F5132 controller IC.
Take note of what the description is telling you in the TEST REPORT. What Simon does not understand the output never goes to 0% because the circuitry uses 10 ma from the output. Anyone who has electronic design experience knows you cannot power anything with ZERO VOLTS, AMPS & WATTS. Thus the output never goes to ZERO. That tells you Simon Mathews is a pretender.
I use to work in Telecom for 30 years for a major telco and have installed thousands of DC battery plants. After being laid off in 2003 I started my own engineering company doing the same work for more money, an dhave built over 200 Off-Grid Battery systems at remote cell sites, and some large grid tied systems for Walmart and DOD.
I will use an analogy of filling a bottle with water from a tap where the water supply is the solar panel, the tap and the person turning the tap on and off is the solar controller and the bottle is the battery.
When we start filling the bottle we turn the tap on full. The amount of water flowing into the bottle is limited by the pressure of the water and the resistance to the flow caused by the friction in the pipes and tap. The water pressure is equivalent to the solar panel voltage and the resistance to the water flow in the pipes is equivalent to the resistance of the circuit and internal resistance of the battery.
As the bottle gets nearly full the water starts to fill the neck of the bottle and as the neck is smaller than the body of the bottle the water level starts to rise more rapidly. At this point we slow down the flow of water by turning the tap partly off. When the solar controller reaches its CV point it starts limiting the current going to the battery so the battery voltage doesn't go too high.
When the bottle is full we turn the tap completely off to stop the flow of water. If we are too slow at turning the tap off the bottle will be overfilled.
If the tap is leaky and cannot be turned completely off and the bottle doesn't have any leaks the bottle will overflow. If the bottle has a leak in it (this equates to a Lead Acid battery) the bottle will not overflow if the leak is larger than the water leakage from the tap.
If we get a kink in the tube going into the bottle while the water is still flowing the water pressure in the pipe will very quickly rise to the pressure of the water supply. This would not happen if we could instantly turn the tap off. This is what happens with the solar controller when the battery BMS disconnects the battery. Now if we have a leak in the pipe going to the bottle or a pressure relief valve on the pipe that will let water out when the water pressure rises too high we won't have the problem with the water pressure getting too high. It is not too hard and doesn't add much extra cost to the solar controller to add the extra circuitry and/or software to stop the charging voltage from rising too high.
I hope this analogy has been useful. As far as I can see Sunking either doesn't understand the basic principles of MPPT controllers or he is just trying to make it all sound too complex for anyone else but himself to understand. Maybe it is a combination of both. As I have said before, the devil is in the detail and there is allot of complex detail that an engineer has to know if they are designing this sort of equipment. Hopefully the fundamental principles can be understood by people like you who are prepared to ask questions and learn something new.
Simon
That is a great analogy.
Still not sure what would happen if the GV-5 were paired with a battery that has no low current threshold, and not sure how to easily identify that kind of battery. Will pursue this if and when I have time.
Many, many thanks to you and Sunking for taking the time to answer my questions.Leave a comment:
Sunking, if I understand you correctly, you're saying that at CV, current comes to a stop, and voltage simply remains at that voltage ("set point" is s new term which I think equates to CV voltage). My question is what keeps it there? I think you must mean that either: 1) the set point is equal to the "full" point of the battery, so that the system comes to some sort of equilibrium with no current flow; 2) the controller actively sets current to 0A; or 3) self discharge makes it so that current flow never stops. If the CV voltage of a controller is 14.2V, and the saturation point of a 4-cell LFP is 14.6V, then if there was such a thing as "equilibrium" in an electrical circuit, then the system couldn't be at equilibrium at 14.2V, right? If the controller actively stops the flow, then by Simon's illustration, the "pressure" on the controller would be panel Voc, right?Last edited by Dave C; 05-02-2016, 12:54 PM. Reason: Added language to indicate that I don't know if the word "equilibrium" is ever used to describe an electrical circuit.Leave a comment:
That disconnect would have to be at some low current threshold so the battery never gets to 0A, right?
So for Sunking's suggestion to be a good one, it must be that either: 1) a drop-in replacement battery simulates leakage during charging; or 2) charging current never actually goes to zero with LFP--very close to it, but high enough to let the controller know that a battery is still there. Unless you two agree on this (or someone else weighs in), the only way for me to know would be to test with a battery that has no low current disconnect. Do you agree that as a rule, drop-in batteries have no above-zero low current threshold? Would this be a worthwhile test?
Simon
What sets any solar charge controller apart from say any AC powered source is the Buck Converters power source. Solar is from a Current Source of unknown power at any given time. For an AC power source is a Stiff Voltage Source like from a battery or generator with unlimited power. A 30 amp AC charger can supply 30 amps forever and can regulate voltage from 0 amps to full rated amps. A battery can take as much current as the source can provide. It is that difference in a power source that makes them react differently.
There is no mystery to charging batteries. It does not matter what the battery type is, they all charge the exact same way. All it takes is an understanding of Ohms law and DC 101 circuit theory. There is a great book on batteries. I call it the Battery Bible. It covers every battery types and its characteristics. It is titled HANDBOOK of BATTERIES 4th edition is the latest. You can find free copies of the 3rd edition in PDF if you click the link I just gave you which is still valid today. It is written by David Linden and Thomas Linden. I know David as he chairs IEEE-450 and 455 committee which I was a contributing member before retiring. All you gotta do is read 1400 pages. Start with Chapter 34 as it is the shortest and easiest to understand chapter in the book (Lithium). Nothing to it as they are the easiest battery to charge. FWIW the most complicated and difficult battery to charge in NiMh followed by NiCd, and Pb. The book covers every battery chemistry there is.
Back to Current Sources. Makes no difference is the Current Source is from a Voltage Source or Solar Panel, if you open the load, the voltage goes to the source voltage. A Solar Panel is a Current Source and the controller has a huge capacitor at its output. Your own eyes have seen what happens when the battery is disconnected. Your eyes are not lying to you.Last edited by Sunking; 04-30-2016, 11:46 AM.Leave a comment:
without damage. I think the 8 volt figure is the minimum voltage that the radio will operate at.
Simon
Dave what Karrak and you are not grasping is a Solar Panel and Solar Charge Controllers are Current Sources. I don't expect neither of you to fully grasp it as neither of you are educated technicians or engineers. Simon Mathews aka Karrak is a Consumer Electronics redistributor aka salesman. Not sure what you do. Point is it takes a battery in this application to turn a Current Source into a Voltage Source.
The characteristic of any Current Source cannot be debated. If you open Circuit a Current Source, the voltage goes to the source voltage. In this case that is your Solar Panel. A solar panel specs tell you exactly what voltages and currents it produces under what conditions. For this discussion Voc demonstrates the fact. Voc = Voltage Open Circuit. Current does not flow in an Open Circuit. The other spec is Isc = Current Short Circuit ot how much current the Current source can supply. Isc is at 0 voltage. You rpanel maximum current is at 0 volts of just less than 2 amps. At Vmp can only supply 1.6 amps.
Solar Charge Controllers are not designed to output Zero Volts and Zero Amps. There is no reason for them to do that. If you want 0 volts and 0 amps, you disconnect the panel. For a 12 volt controller, there is absolutely no reason to design the controller to go below 12 volts. Nor will it output 0 amps at any time because the controller gets its power from the output of the controller. It would be self defeating for a Controller to output 0 anything.
A battery is far from an Open Circuit. In fact it has a extremely low resistance. In your case each cell is approx .020 Ohms, and with 4 in series is a total of .08 Ohms. To change the voltage of the battery by 1 volt up or down requires 1 volt / .08 Ohms = 12.5 amps. Now stop and think about that. The only way you can have 12.5 amps flowing is on DISCHARGGE, and the voltage of the battery would go DOWN. For it to go up 1 volt requires 12.5 amps. Where in the Hell is that current going to come from? It cannot come from the panel or controller.
There is only one possible way for a Solar Panel to output Voc voltage. OPEN CIRCUIT with NO CURRENT. If anyone tells you differently, they have no clue what they are talking about.
Can you or Simon recommend any books on how an MPPT controller for LFP batteries operates?Leave a comment:
There is only one possible way for a Solar Panel to output Voc voltage. OPEN CIRCUIT with NO CURRENT. If anyone tells you differently, they have no clue what they are talking about.Last edited by Sunking; 04-29-2016, 02:22 PM.Leave a comment:
