Where to buy 3M solar films
What the dimensions you needed?Leave a comment:
They use cells, panels and necessary materials made by others, just like they probably don't make their own wheels. More like a system integrator function. They assemble/bolt/glue/fit components together. They usually don't manufacture components. They usually/often start out as gear head teenagers and bring their interests to the classroom and shop. Nothing wrong with that.Leave a comment:
How do the college kids make their solar powered vehicles? I'm not really building panels but trying to mount and encapsulate Maxeon cells on a rigid fiberglass surface. I do composites work and have a vacuum system and a large oven capable of reaching 250F. Acquiring the materials seems to be the problemLeave a comment:
Look at BuildItSolar website for ideas. AFKC, DIY solar PV panels is a dead end, unless you can get into a solar PV factory at night and run the vacuum heat laminators and encapsulation machines.Leave a comment:
I'm hoping to build several semi-flexible panels. I would buy ready made, however I need custom shapes to take advantage of the structure these panels will be mounted on. I can't do rigid as they will be mounted on a gently curved surface. I would like to use ultra barrier and 3M encapsulating film however I can't find anyplace to buy it. Any ideas
