Get lost Spammer. Digging up 3 year old post. Moderators are asleep at the wheel.
Looking for a solar tracker controller
This thread is from 2015 and the OP has probably made a purchase decision by now.
He hasn't been here since 2016 so who knows?
Thanks to the newb (or spammer) for bring this unanswered question to the top of the list.Leave a comment:
Part of the issue is latitude. On the equator a long shaft parallel to the ground can turn a bunch of panels.
If you come here at 42 degrees, it is not practical to tilt a long shaft up that far. So the commercial arrays
leave it flat, but add 30% more panels to compensate for the cosine of 42 degrees. Already a lot of the
apparent tracking advantage is going away. Build lots of tilted short shafts with drives, cost gets out of
control and you need a lot of land to avoid shadowing.
My array puts out 20 hp 8 hours a day. Try building something that size on up to industrial, to see just
what the challenges are. One thing the tracker CAN do, is throw off the snow. Mine is still small enough
to allow doing snow removal by hand, with an arrangement optimized for this. Bruce RoeLast edited by bcroe; 09-15-2018, 01:50 PM.Leave a comment:
Ever design a tracking array ? Ever try to maintain one ? Well, if you compare the possible 20 - 25 % increase in irradiance for either a one or two axis tracker, and what's probably an 18 - 20 % or so increase in annual production for mid continent U.S. (Springfield Il, for example) vs. a fixed orientation system that will produce about equal annual output for a larger array, and compare that to the extra expense and maint. and maybe things like insurance, not to mention the hassle and expense of design/possible permitting required for a tracking system vs. those same expenses and hassles of the fixed orientation system, you'll probably be a bit less confused.
The usual bottom line: The tracking array is smaller, but the cost /delivered kWh is probably equal to or higher than the fixed array as are the likely maint. costs. All that is before the real and likely PITA factor of more maintenance hassles.
Pay your money, take your choice, but know that the devil is in the details. Do your homework before you cement an opinion or a decision.Leave a comment:
Looking at some quotes from installers, I can understand why. I guess it only makes sense for DIY people.Leave a comment:
Unfortunately the price and maintenance of a tracking system is far more costly then just adding 15% more panel wattage.
Utilities seem to be able to justify tracking systems but IMO I think they just push out the additional cost to their customers.Leave a comment:
Must be some expensive trackers you are looking at.Leave a comment:
My system under clouds can far out produce a tracker system with the same size inverter. It can also match
the tracker, when its clear. It works by trading the machinery and maintenance of a tracker, for more cheap
panels. Bruce RoeLeave a comment:
Seems like there is no love for trackers. With the amount of output increase from a tracker, I find that confusing?Leave a comment:
For most locations, unless there is a need to spread out the production over a day, or an unusual shading situation, or the power input to a storage device or to the grid must be limited, splitting an array into 2 or more directions will result in less energy production per panel area over time than a single orientation.
For most applications and orientations without those constraints, a single (optimal) orientation will produce more electricity per (say, a day) time period than will multiple orientations of the same total area.
Longer generation periods/day do not automatically translate to more energy collected per day. Nor are multiple arrays more cost effective than one single array of the same total area - usually and commonly, often the opposite.
Multiple axis tracking needs very careful consideration and analysis from all considerations of engineering, cost, PITA factor and other things. As mentioned/usually the case, increasing the size of an (optimally oriented) array is often/usually more cost effective and a more practical option than a tracking array.Last edited by J.P.M.; 09-14-2018, 01:35 PM.Leave a comment:
That's why many have abandoned trackers and use fixed arrays, sometimes split in 2 directionsLeave a comment:
There are lots of them on eBay. I have no hands on experience with them though.Leave a comment:
PQ4 good oneLeave a comment:
