Is it OK to use solid copper wire between panels and charge controller?
Well not so sure I would say the Easy Route if you mean BSEE. ASEE is easier, but still requires a sharp cookie. With that said an EE is a non descriptive, like a Doctor. There are so many disciplines and specialties.
Even a BSEE dunno chit when they graduate. They have only dipped their toe into electronics, electric power, communications, controls, etc. They specialize in nothing and really do not know much, and for some get quite frustrated once they realize the education process has only begun. However they have the tools and fundamentals. What I look for in c graduate candidate is have they taken EIT test and passed.Most electrical engineers never ever take the EIT and PE exam. Once you have the PE license in you chosen discipline opens the world up and is your Meal Ticket. Once you have it you can pretty much pick where you want to live and work, rather than go to where the work is.
Unfortunately (or fortunately depending on how you look at it) the Solid State industry took a nose dive in the mid 70's. So I went on to designing power distribution, lighting and controls for a Consulting Engineer. Expanded that into Energy Management and Programmable Logic Control design. Followed by Project Management. I had the chance to get my PE but then the job had me traveling a lot (80 hour weeks and missing many weekends and holidays) so it was something I let go. It has been an up and down ride across a half dozen different manufacturing companies but now I am back working for a Power Quality Engineering group. I figure a few more years at this but I want to get up to speed on the Solar side and will probably continue along that for a while until I just want to kick back and relax when I get to or past russ's age.Leave a comment:
68 - Still working - got recycled on a project in India working on gas consumption in direct reduced iron plants - back in India - again.
I was quite happy playing until the company showed up asking for assistance - however, another year at the max.
For now I ride my bicycle 20 miles and work out for about 1 1/2 hours a day.Leave a comment:
Even a BSEE dunno chit when they graduate. They have only dipped their toe into electronics, electric power, communications, controls, etc. They specialize in nothing and really do not know much, and for some get quite frustrated once they realize the education process has only begun. However they have the tools and fundamentals. What I look for in c graduate candidate is have they taken EIT test and passed.Most electrical engineers never ever take the EIT and PE exam. Once you have the PE license in you chosen discipline opens the world up and is your Meal Ticket. Once you have it you can pretty much pick where you want to live and work, rather than go to where the work is.Leave a comment:
Maybe we should start a sub group call it the OFBLeave a comment:
57 in a couple of months
My trek in life
trade school to become an electrician
electrician for 2 years moved from helper to estimator
Electrical contractor sent me to school for HVAC.
Left there went to work for AC contractor
Tired of being laid off winters so went to college for Building construction
built a couple hundred tract homes for a builder and got tired of mud.
When mortgage rates hit the 13% mark I did some property management then did the solar thermal thing for Reynolds for a couple of years before it died out.
Switched to remodeling (cleaner and less rain days) doing mostly high end kitchens and baths. (google Clive Christian kitchens and you will see some of the type of work I did) That stuff was extremely expensive and low quality and took a lot to get it to look like in the pictures.
When things went south last time I sat around and came back to the solar business.Leave a comment:
OK I got you by one year, I just will not tell you which way? Hint I qualify for Roth next birthday.Leave a comment:
My trek in life
You do not understand, your meter is not capable of measuring anything less than 1 Ohm. It takes a very expensive meter called a Digital Low Resistance Ohm (DRLO) meter. It is a 4-point Bridge device that pumps either 1 or 10 amps through the UUT, (1-amp for milli-ohms, 10 amps for micro-ohms) then reads out the voltage drop. Your meter only uses a few microamps to measure resistance.
How much is too much resistance when using a small hydraulic terminal clamp?
Do you use one of these DRLO meters after terminating lugs using the tool you first showed?Leave a comment:
No sir, not the same thing. Meggar Trademark name is a high voltage ohm meter to test insulation resistance by applying a stressful high voltage to try to breakdown the insulation resistance to check for leaks. Makes for a quick day of fishing.
In addition a Meggar when used as a 3-point Dead Fall Potential is used to measure th eimpedance of earth electrode systems.
DRLO is low voltage high current. It uses a high current then measures the voltage developed. In other words a current source.
Haven't used one since 1977Leave a comment:
So much to learn! ThanksLeave a comment:
