MPPT mentioned in earlier post
In earlier post we talk about MPPT, here we've info:
Could we make 240v Solar Electric System ?
hook up a series of panels to a home power circuit
Post#159 Reply to:Can I hook up a series of panels to a home power circuit? 12-03-2008
... to make any hook up to the electrical system. Solar panels are direct current (DC) and your electrical service is alternating current (AC). You need inverters and phase matching equipment to attempt these kinds of connections.
For a solar panels system to work correctly you'll need batteries for storing the power, wiring to handle the systems amps, phase converters, inverters, and high wattage solar panels to make your system worth while.Last edited by MarineLiner; 05-17-2009, 08:50 PM.Leave a comment:
Sunny Boy is the brand of a Grid-tied Inverter
Thank you. Since the system should be able to supply power at night it will also have batteries for storage and kept be tied to the grid to enable "net metering".
I'll also copy n paste your replies about "charging" to enrich this thread. Thanks again.Leave a comment:
sunny boy is the brand of a grid-tied inverterLeave a comment:
Transformerless Inverter
If you want use no transformer, you need connect the inverter directly to the power line. This is on-grid system. So you need not batterys. You sell your green energy to the public power line.
You can charge DC240V battery use some special MPPT regulator.Leave a comment:
[QUOTE=MarineLiner;1076]In another post i asked this, but seems not be seen easily as it's in the middle of reply posts.Leave a comment:
In another post i asked this, but seems not be seen easily as it's in the middle of reply posts. [QUOTE=MarineLiner;978]
