Is it possible to combine parallel and Series
Guest repliedFix parallel.jpg -
Guest repliedThanks White Wolf!
I will have to try this schematic out!
Thanks again FriendLeave a comment:
This would parallel the panels. Just like paralleling batteries.Attached FilesLeave a comment:
Guest repliedLeave a comment:
You connect the PLUS of one string to the PLUS of the other and the MINUS of one to the MINUS of the other. I do not think that is what you have drawn.Leave a comment:
Guest repliedCan I connect two Series into parallel? and get double the ampLeave a comment:
Well I am just guessing but I am presuming that picture represents 40 cells wired in series on the left and 40 cells wired in series on the right.
If you wire the top left hand cell for each "panel" together. And then wire the top right cell for each "panel" together. That should put those two sets of 40 cells in parallel.Leave a comment:
Guest repliedWould something like this be Parallel? or just series.1 PhotoLeave a comment:
Guest repliedHow would you wire them in parallel. I drew the picture of solar cells in series. How do I wire them up from there to make them parallel with each other.
Can someone us MS paint and take my drawing and just draw how to make parallelLeave a comment:
With electricity when the voltage is wired in series it adds up. When the amps are wired in parallel it adds up.
So if each of those "panels" provide 1A @ 20v then wiring them in parallel should yield about 2A @ 20v.Leave a comment:
Guest repliedLets say both panels put out 1A @ 20V
How would I connect these in Parallel to get 2A @20 V1 PhotoLeave a comment:
