How connect 2 solar panels in parallel ?
Yup me too, no Jpg.
PeteLeave a comment:
posting so i can view picLeave a comment:
Hi
I want to connect 2 solar panels in parallel, I know that I need to connect the "positive with positive" and "negative with negative", but my question is about how do I connect them together?
I'm attaching an image to clarify my problem.
Do I need to wire with soldier? or how I connect together?
Thanks in advanceLeave a comment:
The first scenario is a reason for using a fused combiner, which does not drop much voltage under normal conditions compared to diodes, yes?Leave a comment:
Solar panels will produce full voltage on even a heavily overcast day or shadowed. It is the amps that they produce which are severely diminished.Leave a comment:
Even if you use Schottky diodes for your blocking diodes, the voltage drop while carrying full current will probably be at least .6 or .7 volts. This may not be much, but it is not zero, and amounts to a 5% or more power loss on a 12 volt Vmp panel.
They are not needed with grid-tie inverters either.
it will drain my amps, or that panels cells will short out. I would rather deal with my 3% loss than fry one of my panels.Leave a comment:
For a standard silicon diode with a forward conduction voltage of .7 volts, the actual drop near full rated current will be about 1.0 volts.
There is internal resistance in the diode which is reduced primarily by increasing the size of the diode.
Like most things, it comes down to what you are willing to pay for the extra power. And that will vary with the application.
People who cannot tolerate even the .3 volt drop will do their reverse-voltage protection with a circuit involving a FET instead of just using a diode -- costing even more and introducing one more potential point of failure.Leave a comment:
They are not needed with grid-tie inverters either.Leave a comment:
I use rectifying diodes on each one of my panels no voltage nor amp loss plus no power will return to my cells. they also work well with grid tie inverters so i got to say bye bye smelly batteries.Leave a comment:
Dear All;
I hope I am not wrong as for being quite a newbie in the field.
What I have studied in the past few weeks on the web, as the amps goes up you have to take care of the wire, fuse and most importantly a charge controller that could support that amount of amps.
So the question is; does your charge controller support that amps.
NaeemLeave a comment:
