Solar system review
I know what they stand for, it just doesen't make sense to me. Correct me if I am wrong, but my understanding is that a watt is the current it is drawing. The same with a KW. When you go to KWh, or watt hours, it is the amount of electricity used durring the specified amount of time. What I don't understand is if my draw is 400watts, how could it also say it is 2KW, or 2,000watts. It seems like it would be KWh, instead of KW. I am wondering if the screen just leaves the "H" out... Or is this not correct? -
Wow. It sounds like it is time to downsize! I think I could get the draw down to 2kw, but that is about it.
I am not quite sure how to read my kill-a-watt meter though. It says my draw is about 400watts, but scroll through a couple diffrent displays and it says it is so and so Kw. Does it mean Kwh???Leave a comment:
Yes the batteries are fine. But the panel wattage is way low as well as the charge controller because of your location winter insolation is going to be on the order of 2 hours or less. With only 2 Sun Hours you will need 1800 watts of solar panels.I thought I gave our location in the biggining, but I may not have. We are on the Western central washington border. The closest town that may be on the map is Goldendale, WA.
The S-1590s have about 1540AH at the 100hr rate, so the batteries are fine. So it sounds like I just need to get a few more panels.
As Mike suggested plug in your zip code and data in PV Watts and it will tell you exactly what you need assuming you have clear view of the horizon east-west-south with proper panel orientation and tilt. Any deviation from optimum will come with a penalty.Leave a comment:
Use this link
to input your zip code, your array specifics, and you will get a month - month listing of the power you can generate, I think they even have an option for tracker.
As is, even with a tracker, you need to account for cloudy days in the winter, and how you will keep batteries charged.
Often, a small backup genset is all that's needed to boost the batteries.
Is your pump 120VAC or 240VAC ?Leave a comment:
I thought I gave our location in the biggining, but I may not have. We are on the Western central washington border. The closest town that may be on the map is Goldendale, WA.I have already told you what you need to do it in solar. To be detailed I need your location. I know how many watt hours you need, and horizon limitations, I just need your location because you do not have 5 Sun Hours in winter unless you live on the equator. If you did, cold weather climate would not be a problem.
All I can tell you for sure based on 2.4 Kwh per day use is you need a battery capacity of 14 Kwh in a cold climate.
12 volts = 1167 AH
24 volts = 583 AH
48 volts = 291 AH
The battery will weigh roughly 900 pounds and need replaced every 5 years or less. That is about all I can tell you based on what info you have provided.
The S-1590s have about 1540AH at the 100hr rate, so the batteries are fine. So it sounds like I just need to get a few more panels.Leave a comment:
12 volts = 1167 AH
24 volts = 583 AH
48 volts = 291 AH
The battery will weigh roughly 900 pounds and need replaced every 5 years or less. That is about all I can tell you based on what info you have provided.Leave a comment:
Sunking, can I just have some help with my setup??? Who cares about Desiel! In some cases, you are very right, but there are times and situations that that is not true. All I would like is help with my solar setup, not desiel generator, which I might add, I know a LOT about. I am not trying to be mean, I am just a solar noobie and need help with my solar system, not my generator.Leave a comment:
OK, generator is out
In winter, lets say you get 3 hours of sun4, 240W panels, is only 960W x 5 hours = 4800w
If you REALLY get 5 hours of usable sun, this may barely work. Rule of thumb with battery systems, with all losses added up, you need to harvest 2x your consumption, to be ballanced.
4, 240W panels, is only 960W x 3 hours = 2880w Can you live with that ? will it run your furnace blower, pump, and fridge ?
The penalty for failure is dead batteries that have to be replaced, upsized, and add another PV array & charge controller. Have that $$ standing by, or plan on using the genset for 30 min in AM, and 30 min PM to charge batteries while PV is undersized.
Additionally, you mention 15KW diesel genset ?? You do know that diesels need to be loaded to at least 50% load, or they "wet stack" meaning that they don't heat up enough to fully burn the oil, and it coats the eghoust system with sludge, and gums the rings up. Expensive overhall to repair. I'm useing 6hp, 3KW genset as main backup.Leave a comment:
That may be true, but diesel doesn't keep to well, so the generator is only good for so long. Also, I only need to run it for a hour a day to pull water from the well. In order to keep the refrigerator cold, I would have to run it at lease 3 times a day.
Another thing is, in the winter, we stay sub-frezzing for over a month at a time, so my draw will be less. I am not sure how much though.Leave a comment:
Generator is still less expensive than solar for emergency backup.LOL. I know it is not a money saving thing. Yes, I have grid, but don't know how long it is going to stay up. I have a 15Kw genset already, setup with a transfer switch. It is great for pulling up water from the well and running the furnace ect, but it is quite expencive to run, and I am building this setup to run my 2 freezers and 1 refrigerator.Leave a comment:
That does not mean anything. To get full insolation you have to have clear view of east-west-south horizon. With only direct sun in wnter from 9-4 is only to going to yield a couple of hours of insolationLeave a comment:
If you have grid power, be advised, solar & battery is going to cost a WHOLE lot of $$, compared to the 20 cents/KWh you can buy it for.
If you need power for blackouts, an inverter genset, with a 5 gallon can of gas, is a much better deal.Leave a comment:
