Announcement
No announcement yet.
Load Share
  • Filter
  • Load Share
    My house is wired 3 phase but I have no 3 phase equipment.
    I have 3 single phase inverters, one on each phase.
    My question is there a way to make them load share?
    My inverters are only 4,000 watt and I have triped 1 inverter off on overload when the other 2 inverters very little load on them.
  • #2
    I'd suggest looking into a variety of three-phase balancers available on the market as these are designed for load sharing across multiple phases. There are some models that allow you to manually switch between the phases, while others are automatic and will do the job for you. Do your research and choose the model that best suits your application. Good luck!
