3x Solar panels - 2x Charge controllers - 1x battery
SLI's can take rapid discharge (cranking the engine over) and rapid recharge (80A alternator spinning up) BUT they cannot withstand deep cycles more than 10% depth, or they start to degrade quickly. -
Sunking - you say SLI's can do 1C?
Would that be the type you recommended as the best compromise for solar over expensive agms and high internal resistance deep cyclers?
The range of charge c/8 to c/12 : is that for deep cyclers only or SLI's too?
And when I get my capacity figure by multiplying that denominator (ie. 8 in c/8) by my sustained panel output amps,
what rating will that refer to in regards identifying the correct battery - C20, C100 or what?
ThanksLeave a comment:
ThanksLast edited by Soundhound; 02-24-2018, 11:32 AM.Leave a comment:
OK last one I promise haha
How would it work to install a switch that chance from one set of 2x batts to, another set of 2x batts,
So that the solar would charge set 1, then once fully charged, switch it over so they would then charge set 2 (And would also switch the load)
Just another idea that popped up...
You may want to research something like little harbor has listed. I do not have any experience with those CC's but they may have the "brain power" to charge each set of batteries one at a time.
From what I remember of your earlier posts If you try to charge all of the batteries at the same time you will need more panel wattage.Leave a comment:
You can buy controllers that will charge two banks of batteries. Morningstar Sunsaver Duo.jpgLeave a comment:
Just another idea that popped up...Leave a comment:
Remember that a balanced system should produce between 1/8th and 1/12th the Ah battery rating for charging. Adding more batteries may work for a short time but then you increase the chance of killing off all of the batteries due to limited or slow charging from too little amps.
That is one of the problems we hear from a lot of people. Their system works just find for a few months and then their batteries can no longer hold the original charge because the plates have been sulfated due to lack of charging amps. Try to keep in mind the long term plan to extend your batteries to their full life instead of a short term plan that will cost you a lot more money.
Ill leave the system as it is for now, nice seeing full charge on the batteries anyway =]
That is one of the problems we hear from a lot of people. Their system works just find for a few months and then their batteries can no longer hold the original charge because the plates have been sulfated due to lack of charging amps. Try to keep in mind the long term plan to extend your batteries to their full life instead of a short term plan that will cost you a lot more money.Leave a comment:
So since removing the other panel, charge controller and 2x batteries, ive noticed my charge controller is now flashing green (meaning batteries are at max charge,
Would it be worth lobbing another battery on or should I keep it as the 2?Leave a comment:
I have had been involved with solar since the mids 70's. I am glad it has finally made some headway as one possible energy sources. But I have also been in the electrical power industry for over 40 years and know that RE is just not enough to keep the lights on 24/7. We still need nuclear or fossil fuel powered generation. But I do enjoy solar technology.Leave a comment:
FWIW LiPo batteries we use are heavily abused. Discharge rates are taken to extreme levels of 6 watts per AH/cell. If you did that to a Pb battery would be a disaster and a melt down. Not even EV batteries are called to discharge at 20 to 30C. Take that 12 volt 60 AH battery and apply a 6 watt/AH/Cell discharge to it and you are talking hitting that battery with 6 watts x 60 AH x 6 cells = 2160 watts. That is enough to melt the lead plates inside.Leave a comment:
I've always been a massive fan of Solar, and the fact you can get electric from the Sun, and not some big company.
So I really appreciate the time you have all taken to reply to my very noobish questions, and have helped me understand how these systems are calculated =DLeave a comment:
OK so you are a RC Toy Man like myself. I fly 3D planes. So you have some understanding of Amp Hours and C-Rates. Unlike LiPo batteries where RC guys talk about 20C, 30C Discharge rates, and 1C up to 5C charge rates, Pb batteries cannot do that. Instead C-Rates are expressed at opposite much slower rates like C/8, C/10, C/20. Pb batteries require at least a C/12 charge, and cannot be charge real fast and generally speaking no faster than C/8. There are some exceptions, like golf cart batteries that can be charged faster up to C/4. The upper limit has more to do with gassing and boiling over. Not good.
Fortunately solar lends itself well to Solar application because if you use recommended practices charge rate falls C/12 to C/8. The ideal charge rate is C/10. Ok where this is leading is if you have a 200 AH battery, ideally you want to charge it at 20 amps, Well if that is a 12 volt battery using a MPPT Controller requires 250 watts of solar panels give or take 50 watts. So as you can see panel wattage and battery are matched to work with each other. If you have a 240 watt panel your battery AH capacity is limited to the C/8 C/12 boundary.
MPPT CHARGE CURRENT = PANEL WATTAGE / BATTERY VOLTAGE.
240 watts / 12 volts = 20 amps.
So at C/8 the smallest battery you can use is 8 Hours x 20 amps = 160 AH.
At C/12, the largest is 12 hours x 20 amps = 240 AH.
Ideal size is 10 Hours x 20 Amp = 200 AH
So a pair of 225 AH 6-volt golf cart batteries is a good match for a 240 watt panel.
Now your turn. What size for the 75 watt panel?
@ C/10 = 10 hours at 6.25 amps = 62.5
So an example from a quick search on Google is the Bosch L5.
And just to clarify, 10C 1300mah Lipo, in theory could be charged at 13 amps
However with a 60ah Pb, at C/10, can only be charged at 6 amps?Leave a comment:
My new laptop is arriving today and that will be the main thing, however will be working out requirements for each component during the rebuild. Which has now turned into a bigger headache than if i just left it hahaLeave a comment:
