Dear Mike90250,
I am using 5 CFL (15 Watt) + 4 Ceiling Fans. All are connected to this Inverter through Power Line.
Electricity Line is coming directly to Electricity Meter from Electric Pole.
I want to reduce my electricity bill by using solar power so which type of equipments i need to do the same.
Thanks in advance.
Regards
Help Required for Installing Solar Energy at my Home
Don't buy anything more!
What is your current electric bill watt hours (or Killowatt hours) for average month last year ?
That's the place to start.
Then:
Is the grid in your area reliable ?
Do they allow Grid-Interactive (Grid tie) inverters ?
If you want to take appliances OFF the grid, and run on batteries, that will cost twice as much
as simple grid tie.
One battery that you show, will run a computer and a couple lights for a few hours.Leave a comment:
Dear Friends,
Hi to everyone. I am new here and need some help to install solar energy at my home to reduce electricity bill.
I am having 650 VA home Inverter with 12 Volt Battery.
I want to know that for solar energy i have to buy another inverter or my old home inverter will work on solar?
If i want to use solar power in day as well as in night also than what steps i have to take? For Example if i have connected solar panels with my battery and battery with my inverter than can i use the solar power at the same time of charging battery?
How many Solar Panels are required to charge my 650 VA home inverter battery???
What about the cost of one solar panel?
Thanks in advance.
