I understand that these are useless for the intended purpose of moving air.
My question is
Can I connect the cells together and charge up anything etc. iphone, light or something better?
Thank You.
What kind of power/project can be accomplished with 20 Auto Cool Ventilation Systems
Well if each one produces 0.2 watts then 20 without any losses could produce 4 watts which will power just about nothing.
Don't waste you time with them. They were designed to move a little (very little) air into your car without having to change out batteries. It is a complete gimmick to get people to think "GREEN" which they are not.Leave a comment:
If you put as many of them in the windows that will fit you might cool the car down a degree or two on a sunny day.Leave a comment:
Complete waste of money with no added value. A cracked open car window does the same thing and cost you nothing. A single beer fart will generate more energy.Leave a comment:
Hi,
I received 20 Auto Cool Ventilation Systems.
Can I connect them together and produce some power?
I was able to find some info on them.
The solar panel in the vent measured only 2.1” x 2.1”
solar cells encapsulated in that area measured only 1.1” x 1.65”
voltage measured 2v
The short circuit current, when exposed to direct sunlight, measured about 100ma.
Power 0.2 watts
Can these solar cells produce something of use?
If they can do something what is the proper technique to connect them?
I think it could be a fun project, hope the results prove to produce some energy.
Thank You for you help.
