I am totally new for solar energy panel and other thing related solar. from last 10 days i was googling and found this forum. this a good forum for carry on knowledge base article question and answer regarding solar panel related things. I have two microtek sine wave 875 VA inverter and two Exide battery 150 ah each . i want to run one computer and two fan in the day time and two fan and two tube-light or CFL indeed of tubelight with solar energy please suggest me what i do for this. thanks to all helping me.
What I Do (How much watt solar panel purchase for me)
Welcome.
Here's where to start: http://www.solarpaneltalk.com/showth...Battery-Design
You can use a fancy meter (cheap too) called a Kill-a-watt, and plug your gear into it, it will measure and totalize your power. 24 hours is a good start, a week is better.Determine the load in energy for a 24-hour period. Not the watts, but the watt-hours.
Determine the size of the solar array to be used.
Determine the battery size and type.
Determine charge controller size
MikePowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
