Hi
I already have and manage 4 grid-tied solar setups.
In all these I have a UPS accepting AC Mains ( 220 V ), and I connect the Cable coming from Solar Charge Controller to the battery bank of the UPS.
Now at day-time, if UPS's AC Mains is switched ON, then the batteries get charged from AC mains, and not from DC incoming current from panels. I guess the reason for this is that AC mains is coming at 220V, whereas the DC Solar is coming at 24VDC or 48VDC.
I am looking for a device or a circuit through which I set DC Solar as First Priority, and AC mains as Second Priority. So in day time, with sun shining the batteries get charged from DC Solar, and in evening when sun goes down, and batteries come to 50% Discharge level, then the battery charging be done through AC Mains.
There are certain Inverters and UPS available in market, which already have the above mentioned DC Priority feature inbuilt into them. But as I already have UPS, so I do not wish to spend money on buying these new UPS. I like to buy a circuit box, to which I give 2 inputs : AC Mains, and DC Solar, and connect the device to UPS as well as batteries. This circuit be able to monitor battery Discharge levels as well, and at time there is no sun, and battery volts drop to 50% then it should start the AC mains current to charge the batteries, not before that. And next day in morning, as sun comes up it should again shift back to DC Solar Charging.
Any ideas about such device or circuits ?
Regards
Regards
