Grounding solar panels on a RV or trailer.
A good example would be say a glass extrusion factory. If the power goes off the glass cools and hardens cause a lengthy shut do to remove solidified glass. Same with say a refinery or any other continuous process. Another good example is elevators and fire pumps in high rise buildings. Read up on the NEC and Fire Pump systems are required not to be grounded, it is too critical.
So now maybe you understand why I say grounded systems are unreliable and dangerous. It is contrary to everything you have been taught and thought you knew huh?MSEE, PEComment
