Rotating banners with links
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Panel on which side of the roof?
  1. #11
    Administrator
    Join Date
    Feb 2011
    Location
    Annapolis Md
    Posts
    4,342
    Default
    Quote Originally Posted by Jaxx View Post
    Even with the roof slope facing west instead of south?
    Yes even with the roof facing west. A steep slope will reduce harvest a moderate one will reduce less.
  2. #12
    Default
    Do not mess with tilting them up.
    If you are anywhere from due E through S to due W, just go with the pitch and orientation the roof provides. The added cost of racking, labor and the engineering issues that are involved with the added wind load (you now have a sail catching considerable wind forces) are now way more than any potential benefit gained from slighly better production. Finally , your neighbors will hate the way it looks al tilted up and angular. You want solar to be a good thing , right? Moreover, making quality, high V connections between arrays is not the easiest. Simple is what works.
    If you put 'em down co-planar with the roof pitch (same angle) you also won't have inter-row shading. Interrow shading in particular can be extremely damaging to output.
    West is excellent:
    you benefit from time-of-use rates in CA don't you? So west is even better than South, b/c you are credited high rates in afternnoon!
    Morning fog also biases your decision to a sunnier West exposure.
    If you are grid-tied a very flat angle is fine as year round production is what counts, not winter when the panels could be steeper.
    As long as you don't go flat all the way, min. 5 degrees.
    Good luck!
  3. #13
    Default
    Can someone else also speak to the "tilt vs no tilt" topic specifically for my case?
    Thanks a lot!
  4. #14
    Join Date
    Jul 2009
    Location
    Izmir, Turkey
    Posts
    5,908
    Default
    Hi Jaxx - Try using the Sharp solar calculator http://sharpusa.cleanpowerestimator.com/sharpusa.htm
    It allows you to change the tilt angle and see the calculated affect on production - then you can determine whether or not it is worth the cost.
    It does make a difference.
    Russ
  5. #15
    Join Date
    May 2009
    Location
    off grid retirement in Northern Calif
    Posts
    5,970
    Default
    use PV Watts to calculate http://www.nrel.gov/rredc/pvwatts/
    My GT array in Los Angeles, was on a west facing roof, and produced just fine. AM fog was the deciding factor, if I had a south roof, there would have been little yearly difference in harvest !
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
